[GiDlist] repeated coordinates
Posted: Fri Jan 11, 2002 6:09 pm
Hello Gid users,
I'm attempting to mesh a simple cylinder, internal radius 100, external 110, height 300, with linear brick elements. (using Gid 6.1.2)
If I create a quarter of the cylinder and then use the copy option to produce the full cylinder I get problems when writing the mesh file using 'Write Calculation File' option. When I output the node numbers and corresponding cordinates, with boundary code, to a *.dat file certain nodal co-ordinates are repeated. This causes my FE code to crash in its initial stages.
I am using the *canRepeat* command in the *.bas file for surface pressures which are written later, so i assume this is not the problem.
I'm using the copy option with the quarter cylinder since you need six surfaces to use hexahedra elements. The in-built cylinder creator is only valid for 2D problems. Can anyone help me with this problem??
Thanks in advance,
Matthew Profit
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020111/93cd2b60/attachment.htm
Thanks in advance,
Matthew Profit
