[GiDlist] Two small problems
Andrea Calaon
Post by Andrea Calaon »
Hi everyone,
I have two minor problems I would like to get rid of:
* In EndGIDProject I use this code:
if { $NewProblemType == "Yes" } {
after 1000 RestoreColors
but the RestoreColors doesn't work properly, and sometimes
I need to give the same open command twice for opening a
.gid "directory-file". Is there any other more reliable way to
restore the original colours without using the "after
command"? (changing the time delay doesn't eliminate the
problem).
* When I open a file that belongs to my ProblemType having
the ProblemType already loaded I always receive this
message:
Project 'utilities' doesn't exist or it is a
problem type. Leaving.
Apart from the message itself, this hasn't caused any more
troubles and I normally just close the dialog.
I have no Idea where this could come from, and I tried to
modify something but nothing has worked ...
Thanks in advance for any suggestions
Best Regards
Andrea Calaon
Ashurst Lodge, Ashurst
Southampton, Hampshire
SO40 7AA, UK
Fax office: +44 23 80 292 853
Mobile: +44 7766 488 225
WIT Press on the web:
http://www.witpress.com
Look for information on the NEW eLIBRARY and books at :
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031216/c1e56527/attachment.htm
