[GiDlist] Loading of RES file
Posted: Thu Nov 27, 2003 9:05 pm
by Eduardo Campello
Hi!
I have been using GiD as a pre- and post-processor tool for my Finite Element code since 2001. I have been a very happy and enthusiastic user of GiD up to now. Last week I was trying to change the format of my output files in order to improve the efficiency of my GiD postprocessing stage. I decided to group some nodal results with the keyword "ResultGroup", instead of the "Result" keyword I have been using so far. Following the instructions at GiD manual, the appropriate changes in the file structure were made. However, when loading the new ".res" file in the GiD postprocessor, a Windows error message pops up in the screen, and says "The exception unknown software exception (0xc00000fd) occurred in the application at location 0x007e54d7". Upon clicking in the "cancel" button a Visual Fortran Debugger is automatically initiated and prompts "unhandled exception in gid.exe: 0xC00000DF: stack overflow". I looked for errors in my ".res" file but I could not find any. Then I decided to run the example from "HelpPostprocess data filesNew postprocess results formatresults example" and I found that the same error occurs when loading the ".res" file. Is there any tricky thing in using the keyword "ResultGroup"??? (I am using the 7.2 version of GiD) Attached to this email you can find the mesh file and the result file that I have been trying to use (these are the examples from GiD manual). I appreciate very much your kind attention, and wait for your reply as soon as possible.
Gracias!
Eduardo Campello
Department of Structural and Foundation Engineering
University of São Paulo, São Paulo - Brazil
Phone/Fax: 55 11 3091-5367 and 11 55 3091-5181
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031127/9786eb75/attachment.htm
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031127/9786eb75/attachment.obj
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031127/9786eb75/attachment-0001.obj
Posted: Thu Nov 27, 2003 10:43 pm
This is corrected bug.
Update the the last available beta version: at this moment 7.4.4b for Windows and Linux
Posted: Fri Nov 28, 2003 4:43 pm
by Eduardo Campello
Enrique, thanks a lot for your quick reply and help.
regards from the tropics,
Eduardo Campello
Sent: Thursday, November 27, 2003 6:28 PM
Subject: Re: [GiDlist] Loading of RES file
From the beta versions section: http://www.gidhome.com/download/do07.subst
Note: your GiD7.2 password remain valid for all 7.x versions
Cc: miguel at cimne.upc.es
Sent: Thursday, November 27, 2003 10:01 PM
Subject: [GiDlist] Loading of RES file
Hi!
Gracias!
Eduardo Campello
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031128/0055b005/attachment.htm
