This face elements are implicitly defined by the element connectivities, not exists explicit inside GiD
The implicit GiD local numeration of the element faces are:
Triangle: 12 23 31
Quadrilateral: 12 23 34 41
Tetrahedra: 123 243 341 421
Hexahedra: 1234 1562 2673 3784 1485 5876
Your code must enumerate this faces, for example, if your code names A,B,C, the three faces of a triangle, then can use some as:TRIANGLE FACES:
Face A: *ElemsConec(1,int) *ElemsConec(2,int)
Face B: *ElemsConec(2,int) *ElemsConec(3,int)
Face C: *ElemsConec(3,int) *ElemsConec(1,int)
Also, if you have a condition over a face of a triangle (a edge), you can identify the implicit face A B or C with globalnodes
*Set elems(triangle)
*Set Cond Line_Face_Load *elems
*loop elems *OnlyInCond
*if(GlobalNodes(1,int)==ElemsConec(1,int))
FACE A
*elseif(GlobalNodes(1,int)==ElemsConec(2,int))
FACE B
*else
FACE C
*endif
*end elems
Or more simple, using the localnodes command
*if(LocalNodes(1,int)==1)
FACE A
*elseif(LocalNodes(1,int)==2)
FACE B
*else
FACE C
*endif
*end elems
nzwyc at sina.com
To:
Sent: Saturday, November 08, 2003 10:39 AM
Subject: [GiDlist] is possible to get the every side of ele
hi,GID group,
when i use GID, i want to get the information about the side of each elements. By the command GlobalNodes, after I applied some condition to some element, I only can get the out-side face of element. are there any way to get the every side of each element? include the side of internal element. for example, I want to get the all out-side face of one layer element. how can i do?
regards
URL:
http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031110/f396f5bb/attachment.htm
Name: not available
Type: image/gif
Url :
http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031110/f396f5bb/attachment.gif
