hi,GID group,
when i use GID, i want to get the information about the side of each elements. By the command GlobalNodes, after I applied some condition to some element, I only can get the out-side face of element. are there any way to get the every side of each element? include the side of internal element. for example, I want to get the all out-side face of one layer element. how can i do?
regards
[GiDlist] is possible to get the every side of ele
This face elements are implicitly defined by the element connectivities, not exists explicit inside GiD
The implicit GiD local numeration of the element faces are:
Triangle: 12 23 31
Quadrilateral: 12 23 34 41
Tetrahedra: 123 243 341 421
Hexahedra: 1234 1562 2673 3784 1485 5876
Your code must enumerate this faces, for example, if your code names A,B,C, the three faces of a triangle, then can use some as:TRIANGLE FACES:
Face A: *ElemsConec(1,int) *ElemsConec(2,int)
Face B: *ElemsConec(2,int) *ElemsConec(3,int)
Face C: *ElemsConec(3,int) *ElemsConec(1,int)
Also, if you have a condition over a face of a triangle (a edge), you can identify the implicit face A B or C with globalnodes
*Set elems(triangle)
*Set Cond Line_Face_Load *elems
*loop elems *OnlyInCond
*if(GlobalNodes(1,int)==ElemsConec(1,int))
FACE A
*elseif(GlobalNodes(1,int)==ElemsConec(2,int))
FACE B
*else
FACE C
*endif
*end elems
Or more simple, using the localnodes command
*if(LocalNodes(1,int)==1)
FACE A
*elseif(LocalNodes(1,int)==2)
FACE B
*else
FACE C
*endif
*end elems
Sent: Saturday, November 08, 2003 10:39 AM
Subject: [GiDlist] is possible to get the every side of ele
hi,GID group,
regards
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031110/f396f5bb/attachment.htm
Name: not available
Type: image/gif
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031110/f396f5bb/attachment.gif
Triangle: 12 23 31
FACE A
FACE B
*else
FACE C
*endif
*end elems
FACE A
FACE B
*else
FACE C
*endif
*end elems
hi,GID group,
regards
Name: not available
Type: image/gif
