Hello:
I am trying to run GiD 7.2 from a PC running Windows NT Service Pack
6. GiD is installed on the D drive, and the user has Administrator
privileges. At first sight, the installation has completed correctly (same
files than on another PC where GiD works).
The PC is equipped with a graphics card Matrox G450 Millenium LEAP.
The problem is the following: when I try to execute GiD.exe (via the icon,
programs menu, or from the command prompt), nothing happens. The gid.exe
process does not even seem to get started.
Can you recommend some debugging procedures?
Philippe
[GiDlist] Installation problems - GiD 7.2 - Win NT
[GiDlist] How to show only some of the conditions?
Is it possible to show only some of the conditions in the GiD
postprocessor? Thanks.
Wenshui Gan
Wenshui Gan
By the moment there is no posibility to visualice each condition
separatelly. It's a good idea, i'll work on it for the next version.
[mailto:gidlist-admin at gatxan.cimne.upc.es] En nombre de Wenshui Gan
Enviado el: martes, 07 de octubre de 2003 19:50
Asunto: [GiDlist] How to show only some of the conditions?
Wenshui Gan
http://gid.cimne.upc.es/mailman/listinfo/gidlis t
Wenshui Gan
1 - Can try to install on the drive "C" instead "D".
In fact, it's not necessary for GiD to run the installation, must only
copy the files (and create/restore manually a direct link to gid.exe)
(to run the installation program is needed to have administrator
privileges)
2 - Can tryalso to run GiD deactivating the OpenGL hardware acceleration:
After the GiD instalation, it's added to the start menu a "GiD safe
mode" command
(if not run the installation, can start this safe mode manually with
"gid.exe -openglconfig")
This command open a previous window, select "Software OpenGL".
From: "Philippe Bouchilloux" pb at magsoft-flux.com
To: "GiDList" gidlist at gatxan.cimne.upc.es
Sent: Tuesday, October 07, 2003 6:24 PM
Subject: [GiDlist] Installation problems - GiD 7.2 - Win NT
Hello:
(same
Philippe
privileges)
mode" command
Hello:
(same
Philippe
