Dear GiD Team,
I should process a surface, but it is discrete.
Do you know a way to create NURBS line from these points?
or have you got an interpolator program?
Thanks in advance!
Gero.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030819/39d7e751/attachment.htm
[GiDlist] Discrete Surface
1) first you must import the points (for example using a bach file)
2) you can create manually auxiliar nurbs lines picking some existent points (mode join when selecting, use control-a to swap this mode)
3) create surfaces using this lines as boundary.
You can also try to directly create a untrimmed nurbs surface, from the points cloud (Create-Nurbs surface-By Points).
Note: this last option only approximate the base points, without interpolation.
Sent: Tuesday, August 19, 2003 10:12 AM
Subject: [GiDlist] Discrete Surface
Dear GiD Team,
Thanks in advance!
Gero.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030901/7f47b6ec/attachment.htm
Dear GiD Team,
Thanks in advance!
Gero.
