[GiDlist] A question about Mesh extrusion
edodo
Post by edodo »
Dear,sir/madam,Enrique Escolano
There is a sample in attached files. You should tanslate to Mesh view in Gid When you open the files of "sa.gid",And I create a bach file,butTHe model which you import bach files are better than the sa.gid,but there are some wrong on the boundary.
BTW,I will get different model when i import sa.bch? Why?
Thanks for your help
======= 2003-07-24 14:53:00 You wrote:=======
Send us a small sample and the procedure to obtain this error.
Note: If you use a version previous to 7.4.2-b, must update (from the web
section download beta versions). Some bugs can be corrected.
Sent: Thursday, July 24, 2003 3:12 AM
Subject: Re: Re: [GiDlist] A question about Mesh extrusion
Dear,Enrique Escolano
There are some error in this way when I use Offest.Can you help me.
======= 2003-07-22 20:26:00 You wrote:=======
This feature is also available in previous 7.x versions.
Select mesh view, and then open the "copy window".
Can extrude elements by translation, rotation, etc.
Sent: Tuesday, July 22, 2003 11:00 AM
Subject: [GiDlist] A question about Mesh extrusion
Dear GiD teams
There are a new availab in GID 7.4.2b of Mesh extrusion,But I can't
find it in Copy windows! Can you help me?
Fegen software Co.,Ltd
http://www.fegensoft.com/english
086-10-82131600
086-10-82121900
ShaolinZhou
fea at eyou.com
2003-07-22
086-10-82131600
086-10-82121900
ShaolinZhou
fea at eyou.com
2003-07-24
086-10-82131600
086-10-82121900
ShaolinZhou
fea at eyou.com
2003-07-25
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030725/60a88725/attachment.obj
Post by Enrique Escolano »
Yes, This is a bug (a variable not initialized), with random results.
It'is corrected for the next beta version (the next week be available).
Note: It's possible to generate prims by triangle extrusion, but this
element type has a very small support in GiD at this moment (cannot be
loaded in postprocess or see boundaries in preprocess, etc).
Thanks for your bug report.
Sent: Friday, July 25, 2003 3:52 AM
Subject: Re: Re: Re: [GiDlist] A question about Mesh extrusion
Dear GiD teams
086-10-82131600
086-10-82121900
ShaolinZhou
fea at eyou.com
2003-07-22
086-10-82131600
086-10-82121900
ShaolinZhou
fea at eyou.com
2003-07-24
086-10-82131600
086-10-82121900
ShaolinZhou
fea at eyou.com
2003-07-25
