Thanks for the tip but I still have a problem
I have the following as a .bas file which works OK when I have a line
between the points but when I delete the line it reports that
CondNumEntities(int) is zero ?
.bas file:
Number of Point charges
*Set Cond Point-charge *nodes
*set var numchg(int)=CondNumEntities(int)
*numchg
node value(Coulombs)
*loop nodes *OnlyInCond
*NodesNum *cond(1)
*end
Any thoughts?
Is there a way of setting the Utilities-Preferences: Meshing , and select
"Mesh Always by default" for
Points to be always on when the specific problem type is selected?
Thanks in advance
Mark
-----Original Message-----
Sent: 12 May 2003 14:34
Subject: Re: [GiDlist] meshing
By default, isolated points are not meshed as nodes, but you can change this
setting with:
Utilities-Preferences: Meshing , and select "Mesh Always by default" for
Points
Note: The nodes are hidden by default, but can show their labels.
(or show written "escape escape View Entities Nodes" in the command line or
with the right buttons)
Sent: Monday, May 12, 2003 2:39 PM
Subject: [GiDlist] meshing
I have an electrostatics application where I have a surface & discrete
point
charges not on the surface.
I have found that the only way to write out both the surface mesh and the
points to a mesh file is to join the points to a dummy point with lines to
make them linear elements.
Is there a more elegant method to enable both surface elements & points to
be written to a mesh file?
Thanks in advance
Mark
GiD6.3.0b & win98
Version: 6.0.458 / Virus Database: 257 - Release Date: 24/02/03
the error.
[GiDlist] meshing
[GiDlist] meshing
Your problem type can change automatically this GiD variable from tcl with
.central.s process escape escape escape utilities variables ForceMeshEntities 1
It is recommended to restore the old value when the problemtype is unloaded. To ask GiD for the current value, use:
set oldvalue [.central.s info variables ForceMeshEntities]
But inother hand, you have reason. If only are generated the nodes, without elements, the conditions are not transferred automatically to the mesh. This bug is not corrected until a next beta version.
Sent: Monday, May 12, 2003 6:20 PM
Subject: RE: [GiDlist] meshing
.bas file:
*numchg
*NodesNum *cond(1)
*end
Any thoughts?
Thanks in advance
Mark
setting with:
Points
point
Thanks in advance
Mark
GiD6.3.0b & win98
the error.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030512/312051d0/attachment.htm
.bas file:
*numchg
*NodesNum *cond(1)
*end
Any thoughts?
Thanks in advance
Mark
setting with:
Points
point
Thanks in advance
Mark
GiD6.3.0b & win98
the error.
