I installed GID on a Linux box (Debian, woody with sarge and unstable parts)
What Glibc version needs GID? And what other versions of libraries are
required?
The problems I have:
- instal verion not working: segmentation fault
- I cannot do any calculation: cannot find problemtype.dat file and when
it can find it it cannot open or run. Because I'm not at that computer I
cannot phrase the exact error.
- retrieve problem type list causes a segmentation fault.
Any help is appriciated.
Johnny
[GiDlist] glibc version?
[GiDlist] memory consuming animation of results
Hello GiD Team,
when running an animation with GiD 7.3b I realised a steady increase of
memory usage by GiD. Usually this wouldn't cause any harm, but when
running an animation overnight GiD will produce a memory overflow and
may cause to crash the computer.
Good luck in finding the probably missing dealloc command in your sources,
Stefan Bergmann
Dipl.-Ing. Stefan Bergmann
Technische Universität Berlin
Fachgebiet Grundbau und Bodenmechanik
Sekr. TIB1-B7
Gustav-Meyer-Allee 25
D-13355 Berlin, Germany
email stefan.bergmann at tu-berlin.de
phone +49-30-314-72347
fax +49-30-314-72343
Stefan Bergmann
Sekr. TIB1-B7
it uses glibc 2.2.
GiD is compiled statically, and the installator too, so
no external libraries are needed.
There is a dynamic version:
ftp://www.gidhome.com/pub/gid_adds/Linux/gid7.3b-dyn.tar.gz
to take advantage of the graphics acceleraiton provided by
the X server.
Which version of Debian are you using?
To do any calculation you have to install a simulation code,
for instance Rambshell, Tdyn, caltep, emant, or any other.
take a look at http://www.gidhome.com/gidplus/
or into the option menu 'Data-Problem type-Internet retrieve'.
required?
Johnny
it uses glibc 2.2.
the X server.
required?
Johnny
