[GiDlist] Fw: how to get the library
Post by Enrique Escolano »
You have reason, if you try to compile testpostfor.f from Compaq Visual FORTRAN
(or another compiler from MS Developer Studio), it exists a bug in the sample:
Instead:
CALL GID_BEGINSCALARRESULT('Result','Analy.',1.0,0,0,NULL,NULL)
must use:
CALL GID_BEGINSCALARRESULT('Result','Analy.',1.0,0,NULL,NULL,NULL)
Another small change:
Instead
CALL GID_WRITECOORDINATES(idx, rx, ry, 0.0)
use
REAL*8 rz
rz = 0.0
CALL GID_WRITECOORDINATES(idx, rx, ry, rz)
I attach testpostfor.f with this changes, and avoiding the use of RANDOM for this sample, because is not FORTRAN standard, and
the syntax can change between compilers.
To: escolano at cimne.upc.es
Sent: Wednesday, April 30, 2003 4:10 PM
Subject: Re: how to get the library
escolano,hi!
Thank you help me! today i try to get the library with Microsoft C++, it is ok! but i meet the follow errors when i try to compile that example written in Fortran Language---testpostfor.f
testpostfor.obj : error LNK2001: unresolved external symbol _GID_BEGINSCALARRESULT at 44
Debug/gidpost.exe : fatal error LNK1120: 1 unresolved externals
i think i lost the subroutine GID_BEGINSCALARRESULT when i compile the library in Microsoft C++ because when i delete the line CALL GID_BEGINSCALARRESULT, it can run without any problem. Do you have any idea about this?
thanks a lot
best regards
--__--__--
Message: 4
Subject: Re: [GiDlist] how to get the library
Date: Mon, 28 Apr 2003 11:16:57 +0200
What's your compilation problem?
You compile on Linux/Unix, Windows using MS Visual C++, ...?
You can compile gidpost.lib ?(read gidpost.html to compile)
Yon can compile the sample use testpost.c using this library, to create
testpost.exe?
This library is tested under Linux and Windows.
To: "gid" gidlist at gatxan.cimne.upc.es
Sent: Tuesday, April 29, 2003 3:29 AM
Subject: [GiDlist] how to get the library
everybody,hi!
with GID 7.2 and some other files which are written in C language, it is
possible to write the result file in binary format in order to compress the
size of result file. I got some gidpost files which are written in C
language from GID website. from readme.txt, i was informed that i can get a
library file by compiling those resource files and with the library file, i
can write the *.flavia.msh and *.flavia.res in binary format. but i cann't
compile those resouce file successfully. i don't know if somebody try it or
not.
i think it is very meaning to write the two result file in binary format
because with ascii format the two files are always very big sometimes,
especially you have a lot of results in your result files.
thanks a lot
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030428/ade8f83f/attachment.htm
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030428/ade8f83f/attachment.obj
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030428/ade8f83f/attachment-0001.obj
Malte Neumann
[GiDlist] postprocessing with changing mesh
Post by Malte Neumann »
Hi everbody,
I would like to postprocess results on a changing mesh, i.e. the number of
nodes and elements might change (increase and decrease) during the simulation.
Is there a way to postprocess such results other than writing a new .msh
and .res for each new mesh and not being able to create animations?
Thanks for any help.
Malte
Malte Neumann
Institut fuer Baustatik / Institute of Structural Mechanics
Prof. Dr.-Ing. Ekkehard Ramm
Universitaet Stuttgart / University of Stuttgart
Pfaffenwaldring 7, D-70550 Stuttgart, Germany
mailto:malte.neumann at statik.uni-stuttgart.de phone: ++49-711-685-6121
http://www.uni-stuttgart.de/ibs/members/neumann/ fax: ++49-711-685-6130
Currently is not supported a "time-step" variable mesh in GiD postprocess.
It is necessary to open each .msh and .res
It is possible to create a tcl procedure (and a window) to automatize, for a
colection of results, this process:
- open an animation file (avi, mpeg...),
- read a mesh and results file
- read a view previously saved in another file.
- save a image to this animation file
-close this animation file
From: "Malte Neumann" neumann at statik.uni-stuttgart.de
Sent: Wednesday, April 30, 2003 12:18 PM
Subject: [GiDlist] postprocessing with changing mesh
Hi everbody,
simulation.
Malte
Malte Neumann
