[GiDlist] loop over conditions
Mihai TEODORESCU
Post by Mihai TEODORESCU »
Hello and thank you for your help. I almost solved my problem.
I met a field in the condition dialog box named "condition number". Then
I sorted the conditions as sugested by Enrique . And finaly I could
filter the informations as I needed.
There is only one problem. The user have to enter for each condition a
different number. If he enter two times the same number the model will
be false. It will be best if this number would be incrementaly each time
a new condition is assigned to the model. Can I do this?
Thank you,
Mihai TEODORESCU
Email: mihai.teodorescu at prevost-industries.com
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030313/eb1e7716/attachment.htm
