[GiDlist] Postprocess: Motion to parts while playing animati
Javier Jimenez
Post by Javier Jimenez »
Hi everybody,
Appreciate to be advised how to write a batch file in order to apply motion (for example: up and down-simulating an stroke action of several mms- and or a rotation of some degrees) to different parts of an assembly while playing animation.
Thank you.
Javier Jimenez
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040115/df7908a1/attachment.htm
Post by Enrique Escolano »
Activate the preference "Write batch file" (Utilities-Preferences), and set the batch filename.
Then all commands are registered inside this batch file.
Then make manually the desired motions (translations, rotations, etc) using the "Move" tool (Utilities-Move), and selecting
the desired entities to move.
After this, can repeat this batch file, for example with utilities-Graphical-Read batch window (can run it step by step, etc.)
With Utilities-Graphical-Animation controls can also save all screen redraws inside an avi or mpeg animation file.
Sent: Thursday, January 15, 2004 6:21 PM
Subject: [GiDlist] Postprocess: Motion to parts while playing animation
Hi everybody,
Thank you.
Javier Jimenez
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040115/720636ec/attachment.htm
