[GiDlist] material interface
Post by Enrique Escolano »
I don't understand exactly your question.
If your results are located over nodes, then if the nodes are shared between
interface elements, the result is the same
for the elements at the two interface sides (the discontinuity is smooted),
maybe you need to duplicate this nodes.
Can also write the results over the elements (at some "gauss points"), and
then this result is not smoothed between elements
Sent: Monday, December 29, 2003 5:18 PM
Subject: [GiDlist] material interface
I have different materials in one structure. After solution, can I
visulize
the discontunity results at the interface of two materials in GID or does
GID
evaluate the nearest points results to show the intersection result. I
attached
the geometry of the structure.
