[GiDlist] problem in .dat
ascosta at portugalmail.pt
Post by ascosta at portugalmail.pt »
Name: not available
Url: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20051214/dbd2334a/attachment.txt
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20051214/dbd2334a/attachment.htm
I don't know what's happening.
Maybe it's some problem related with your problemtype tcl code?
Can you send your problemtype, and the steps to repeat this bug?
Which GiD version do you use?
Sent: Wednesday, December 14, 2005 11:35 AM
Subject: [GiDlist] problem in .dat
Hi!
After i introduce the values for each window menu's i save my problem type before going to another window.
When i open .dat file, the results of *tcl command of .bas appears many times.
This only appens when i repeat this saves.
When i save my project only at the end everything is ok.
Do you know what is the problem?
Thank you. I hope i make myself clear.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20051219/2653a7bc/attachment.htm
