[GiDlist] Fw: Sweeping tool
Javier Jimenez
Post by Javier Jimenez »
Hallo gid team,
Appreciate to be advised how to set up correctly the "Copy Window, Transformation: Sweep"
in order to get an extruded volume similar to the included example (forget the additional cuts), by sweeping the surface along the line as the defined path.
Thank you.
Javier Jimenez
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050929/5d726136/attachment.htm
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050929/5d726136/attachment.bin
Hello Javier,
The current sweep tool has limited to select only a single path curve, you must join your multiple path lines: use collapse points, or create a polyline
Note: your model has some duplicated points, use also collapse to remove duplicateds.
Then you need to orient the path curve in the appropiate extrusion sense: use draw normals, and swap this normal if not agree with the desired sweep.
Then can use the sweep window: select surfaces as source, the path line, and extrude volumes. And select the source surface/s.
(when you select surfaces, the path line tangent is drawn to visualy check if it agree with the desired sweep)
Sent: Thursday, September 29, 2005 11:45 AM
Subject: [GiDlist] Fw: Sweeping tool
Hallo gid team,
Thank you.
Javier Jimenez
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050929/bf875bb4/attachment.htm
