[GiDlist] Rounding an edge
Mark Smith
Post by Mark Smith »
Hi Abel
Thanks for the tip but GiD crashes when I try to blend the edge of the
surface "front" in the attached model with a radius of 0.3 . I select all
10 edges that form the perimeter of front. It make no difference if I make
the object solid.
Am I doing something wrong or is the an example of it not working 100% ?
regards
mark
-----Original Message-----
Sent: 04 August 2005 08:53
Subject: Re: [GiDlist] Rounding an edge
You have this option in the RightButtons menu. Yo acces to it by
Geometry-Create-BlendSurfs. You must specify the radius of the "arc
surface" and the edge you want to "chamfer" (it must be shared by 2
surfaces). This command isn't still working 100% well, so it is in the
RightButtons menu. Probably in the next beta version it will be checked and
placed in normal menus.
ABEL
Sent: Tuesday, August 02, 2005 1:10 PM
Subject: [GiDlist] Rounding an edge
Win 2000 SP4 GiD 7.5.8b
Is there a geometric procedure like "round" where one specifies a radius
then selects the edges of the solid you wish to modify to blend one
surface
into another with the specified radius? or "chamfer/bevel" an edge at a
specified angle?
for lines there is the arc tangent command, but I can not see the 2D/3D
analogy.
regards
mark
transmitted herewith) is privileged and confidential and is intended for
the
disclosure, reproduction, distribution or other dissemination or use of
this
communication in error, please contact us immediately so that we can
correct
the error.
the error.
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050817/649a4a9b/attachment.obj
