[GiDlist] Generating "structured" volumes and hexahedral mes
Timo Hambürger
Post by Timo Hambürger »
Hi there,
i try to build an arbitrary shaped volume, and then to generate a hexahedron
mesh within. But if i build e.g. the gear from the tutorial, and then assign
hexahedron elements to the resulting volume, GiD throws an error when i try
to generate the hexahedron mesh as follows:
Non-Structured volumes can only be tetrahedra or only points.
How can i define the volume as a structured volume? Where is the difference
between structured and unstructured? I did not found anything about
structured volumes at the help-file.
Best regards from germany,
Timo Hambürger
An structrured volume must have exactly 6 faces (topologically is like a
cube).
In order to generate the structured hexahedrals mesh, it's necessary to
manually edit the geometry to divide the volume in parts with 6-faces. Then
you assign the number of division in the three directions.
The last beta versions have a new feature: semi-structured meshes. It
generate triangular prisms. with unstructured triangle faces in two opposite
surfaces, and an structured number of divisions in the extrusion direction.
From: "Timo Hambürger" timo.hambuerger at flexilution.com
Sent: Wednesday, August 10, 2005 9:31 AM
Subject: [GiDlist] Generating "structured" volumes and hexahedral meshes
Hi there,
hexahedron
assign
try
difference
Timo Hambürger
abelcs
Post by abelcs »
This mail is for add some extra information at the mail sent by Enrique to
the GiDlist in relation to the hexaedral meshes.
Using semistructured meshes it's another way to obtain hexahedral meshes.
As you will see, a volume can be meshed with semi-structured mesh if it's a
prismatic volume, where it can be distinguished to top surfaces (master and
slave), and the lateral ones. Lateral surfaces will be meshed with
structured mesh, and top ones can be meshed with any kind of mesh.
Depending on the element types assigned to the volume surfaces, result mesh
will have prism, tetrahedra or hexahedra elements.
The way of choosing the kind of mesh you want (since last beta versions) is
in "Mesh" menú, setting UNSTRUCTURED, STRUCTURED or SEMISTRUCTURED option,
and selecting the geometrical entities you want to mesh.
Abel Coll
Sent: Wednesday, August 10, 2005 3:07 PM
Subject: Re: [GiDlist] Generating "structured" volumes and hexahedral meshes
cube).
Then
opposite
direction.
Hi there,
hexahedron
assign
try
difference
Timo Hambürger
