[GiDlist] GID-Postprocess (blanking figures)
Enrique Gutiérrez Diez
Post by Enrique Gutiérrez Diez »
I am postprocessing some results using GID. I usually load up an image as background and then read results from the .bon .res files using:
"utilities backgroundimg realsizeimg"
By doing so, the grid results overlap the image loaded as background. My question is, is there anyway for blanking part of the grids results with some image or file?? as can be done in surfer for example. I have a grid in which some of the nodes should be covered up or blanked in the final image before creating and image out of it...I guess I could try to do so with surfer but I would like to know if this can be done in GID so I only work with GID, plus I could create a batch file to speed things up.
Thanks a lot.
Tecnocean Ingeniería S.L.
C/ Balmes 184,3º2ª
08006 Barcelona
+34-93-238-8970
www.tecnocean.com
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050711/d51c7ca3/attachment.htm
