Hello everyone,
in order to be able to reset the previous option of
"UseMoreWindows" I need to store the standard variable
value the user is working with. Therefore I guess I should
access the global variable ChangeVarInfo(UseMoreWindows).
But even if the variable is changed to 0 or no, the behaviour
of GiD remains unchanged and windows are used to interact
with the user. I tried the following two expressions:
global ChangeVarInfo
set ChangeVarInfo(UseMoreWindows) 0
set ChangeVarInfo(UseMoreWindows) no
This on the contrary works:
.central.s process Utilities variables UseMoreWindows 0
Which is the difference between the three expressions?
Best Regards
Andrea
[GiDlist] On the object creation again
Hello Andrea,
while greping the gid/scripts directory for
ChangeVarInfo(...)
i found only entries that had the Name
set ChangeVarInfo(Usemorewindows) yes | no | beginner
maybe that's the solution, if the switch/case statement is case-sensitive.
You can even use
central.s disable windows 'value'
The value 0/1 Enable/Disable Windows (GiD displays, or not, windows which require
interaction with the user)
EXAMPLE to disable the interaction windows:
.central.s disable windows 1
to control the apperance of user interaction windows.
good luck. maybe you can post the result of your test.
Thanks in advance
Best Regards
Martin
Andrea Calaon wrote:
Hello everyone,
Best Regards
Andrea
_/ _/_/ _/_/_/ Friedrich Alexander Universität Erlangen
_/ _/_/ _/_/
_/ _/ _/ _/ Department of Sensor Technology
_/_/_/ _/_/ _/_/_/ Paul-Gordanstr. 5, 91052 Erlangen, Germany
Dipl.-Ing. Martin Meiler
tel.: (+49)-9131-85-23140
fax.: (+49)-9131-85-23133
ChangeVarInfo(...)
You can even use
Thanks in advance
Best Regards
Martin
Hello everyone,
Best Regards
Andrea
_/ _/_/ _/_/
Hello Andrea & Martin,
To avoid to open popup windows, must set the GiD variable UseMoreWindows to 0
with
or
GiD_Process Utilities variables UseMoreWindows 0
(they are similar, but I recommend you to use GiD_Process)
This command change an internal variable (of the C/C++ kernel)
ChangeVarInfo(UseMoreWindows) is a Tcl/Tk global variable used to temporary store the value of UseMoreWindows.
When you open the preferences window, ChangeVarInfo(UseMoreWindows) is set to the internal value, and when you press the Accept button the internal value is set to the current ChangeVarInfo(UseMoreWindows) value.
For your problemtype, can use your own Tcl global variable to store the previous state, for example:
#save the current value and set a new value
global BeasyPriv
set BeasyPriv(UseMoreWindows) [GiD_Info variables UseMoreWindows]
#restore the old value
global BeasyPriv
GiD_Process Utilities variables UseMoreWindows $BeasyPriv(UseMoreWindows)
Valid UseMoreWindows values are: Create new point: 0==always 1==ask -2==never
Usually, if you provide to GiD the answer in the same line, then the user won't be asked, and then it's not necessary to deactivate windows.
Can also use this Tcl commands to temporary deactivate redraws, and messages:
GidUtils::DisableGraphics
GidUtils::EnableGraphics
Sent: Tuesday, June 28, 2005 2:20 PM
Subject: [GiDlist] On the object creation again
Hello everyone,
Best Regards
Andrea
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050628/d4293150/attachment.htm
with
or
global BeasyPriv
global BeasyPriv
Hello everyone,
Best Regards
Andrea
