Hi, GiD teams
I have a surface triangle mesh generated by myself. I want to be able to use GiD to convert it to IGES format. The import of the model into GiD is fine, but when the model is exported as an iges file, the file is almost empty in that there is no geometry information or others. The attachment is a testing example. Any suggestion on this?
Thank you
Henry
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050623/d4693937/attachment.htm
Desc: 1310085509-prism.gid.zip
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050623/d4693937/attachment.bin
[GiDlist] Re: Convert to IGES format
The mesh triangles are not written in the IGES file, mainly this is a geometric format.
Can convert each triangle to a geometric surface:
1- Export your triangles with the auxiliary template DXFSAP2000
menu: Files-Export-Using template (only mesh)-DXFSAP2000
2- Import again in GiD this dxf file. You will have a surface by triangle
menu: Files-Import-DXF
3- Export finally this surfaces as IGES
Sent: Thursday, June 23, 2005 6:20 PM
Subject: [GiDlist] Re: Convert to IGES format
Hi, GiD teams
Thank you
Henry
Do You Yahoo!?
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050623/7afdae23/attachment.htm
Hi, GiD teams
Thank you
Henry
Do You Yahoo!?
Hi, GiD teams
Following the steps you suggested as below, I am able to convert a surface triangle mesh (generated by another lcoal programme) to .iges file format. The problem is that the corresponding .iges file contains only point coordinates and line definitions without surface element definitions. So this file can't be used for 3-D mesh generation. Any suggestion on this problem?
The attachment is the test model and its corresponding .iges file.
thanks
Henry
Enrique Escolano escolano at cimne.upc.edu wrote: The mesh triangles are not written in the IGES file, mainly this is a geometric format.
Hi, GiD teams
Thank you
Henry
Do You Yahoo!?
Do You Yahoo!?
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050706/8b442040/attachment.htm
Desc: 3506567449-test.gid.zip
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050706/8b442040/attachment.bin
Url: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050706/8b442040/attachment.txt
thanks
Henry
Hi, GiD teams
Thank you
Henry
Do You Yahoo!?
Do You Yahoo!?
The surfaces of your test.gid model were not written in the IGES file because they are 'surfmesh' entities.
A 'surfmesh' is a GiD pseudo-surface (with a mesh to define the internal shape). This entity cannot be translated to any IGES entity, then only the curves and points are written.
Don't import the triangle mesh with Import-Surface mesh (it create 'surfmesh' entities)
You can use my related trick:
0- Read your GiD ASCII mesh with
menu: Files-Import-GiD mesh
menu: Files-Export-IGES
Sent: Wednesday, July 06, 2005 7:35 PM
Hi, GiD teams
thanks
Henry
Hi, GiD teams
Thank you
Henry
Do You Yahoo!?
Do You Yahoo!?
Translator GID - IGES S0000001
1H,,1H;,3HGID,42Hp:/probeShare/Biomed/AUDILAB/qili/test.igs,,,32,,,,,,1,G0000001
,,1,0,,0,0,,5HCIMNE,9,,; G0000002
110 1 1 D0000001
110 1 STLINE 1D0000002
110 2 1 D0000003
110 1 STLINE 2D0000004
110 3 1 D0000005
110 1 STLINE 3D0000006
110 4 1 D0000007
110 1 STLINE 4D0000008
110 5 1 D0000009
110 1 STLINE 5D0000010
110 6 1 D0000011
110 1 STLINE 6D0000012
110 7 1 D0000013
110 1 STLINE 7D0000014
110 8 1 D0000015
110 1 STLINE 8D0000016
110 9 1 D0000017
110 1 STLINE 9D0000018
110 10 1 D0000019
110 1 STLINE 10D0000020
110 11 1 D0000021
110 1 STLINE 11D0000022
110 12 1 D0000023
110 1 STLINE 12D0000024
110 13 1 D0000025
110 1 STLINE 13D0000026
110 14 1 D0000027
110 1 STLINE 14D0000028
110 15 1 D0000029
110 1 STLINE 15D0000030
110 16 1 D0000031
110 1 STLINE 16D0000032
110 17 1 D0000033
110 1 STLINE 17D0000034
110 18 1 D0000035
110 1 STLINE 18D0000036
110 19 1 D0000037
110 1 STLINE 19D0000038
110 20 1 D0000039
110 1 STLINE 20D0000040
110 21 1 D0000041
110 1 STLINE 21D0000042
110 22 1 D0000043
110 1 STLINE 22D0000044
110 23 1 D0000045
110 1 STLINE 23D0000046
110 24 1 D0000047
110 1 STLINE 24D0000048
110 25 1 D0000049
110 1 STLINE 25D0000050
110 26 1 D0000051
110 1 STLINE 26D0000052
110 27 1 D0000053
110 1 STLINE 27D0000054
110 28 1 D0000055
110 1 STLINE 28D0000056
110 29 1 D0000057
110 1 STLINE 29D0000058
110 30 1 D0000059
110 1 STLINE 30D0000060
110,-0.707107,0.707107,0,0.707107,0.707107,0; 1P0000001
110,0.707107,0.707107,0,-0.707107,-0.707107,0; 3P0000002
110,-0.707107,-0.707107,0,-0.707107,0.707107,0; 5P0000003
110,0.707107,0.707107,0,0.707107,-0.707107,0; 7P0000004
110,0.707107,-0.707107,0,-0.707107,-0.707107,0; 9P0000005
110,0.707107,0.707107,0,0,0.707107,0.5; 11P0000006
110,0,0.707107,0.5,0.707107,0.707107,1; 13P0000007
110,0.707107,0.707107,1,0.707107,0.707107,0; 15P0000008
110,0,0.707107,0.5,-0.707107,0.707107,0; 17P0000009
110,-0.707107,0.707107,0,-0.707107,0.707107,1; 19P0000010
110,-0.707107,0.707107,1,0,0.707107,0.5; 21P0000011
110,-0.707107,0.707107,1,0.707107,0.707107,1; 23P0000012
110,-0.707107,0.707107,0,-0.707107,0,0.5; 25P0000013
110,-0.707107,0,0.5,-0.707107,0.707107,1; 27P0000014
110,-0.707107,-0.707107,0,-0.707107,-0.707107,1; 29P0000015
110,-0.707107,-0.707107,1,-0.707107,0,0.5; 31P0000016
110,-0.707107,0,0.5,-0.707107,-0.707107,0; 33P0000017
110,-0.707107,-0.707107,1,-0.707107,0.707107,1; 35P0000018
110,-0.707107,-0.707107,0,0,-0.707107,0.5; 37P0000019
110,0,-0.707107,0.5,-0.707107,-0.707107,1; 39P0000020
110,0.707107,-0.707107,1,0,-0.707107,0.5; 41P0000021
110,0,-0.707107,0.5,0.707107,-0.707107,0; 43P0000022
110,0.707107,-0.707107,0,0.707107,-0.707107,1; 45P0000023
110,0.707107,-0.707107,1,-0.707107,-0.707107,1; 47P0000024
110,0.707107,-0.707107,0,0.707107,0,0.5; 49P0000025
110,0.707107,0,0.5,0.707107,-0.707107,1; 51P0000026
110,0.707107,0,0.5,0.707107,0.707107,0; 53P0000027
110,0.707107,0.707107,1,0.707107,0,0.5; 55P0000028
110,0.707107,0.707107,1,0.707107,-0.707107,1; 57P0000029
110,0.707107,-0.707107,1,-0.707107,0.707107,1; 59P0000030
S0000001G0000002D0000060P0000030 T0000001
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050711/1a44c86a/attachment.htm
Hi, GiD teams
thanks
Henry
Hi, GiD teams
Thank you
Henry
Do You Yahoo!?
Do You Yahoo!?
110 1 1 D0000001
110 2 1 D0000003
110 3 1 D0000005
110 4 1 D0000007
110 5 1 D0000009
110 6 1 D0000011
110 7 1 D0000013
110 8 1 D0000015
110 9 1 D0000017
110 10 1 D0000019
110 11 1 D0000021
110 12 1 D0000023
110 13 1 D0000025
110 14 1 D0000027
110 15 1 D0000029
110 16 1 D0000031
110 17 1 D0000033
110 18 1 D0000035
110 19 1 D0000037
110 20 1 D0000039
110 21 1 D0000041
110 22 1 D0000043
110 23 1 D0000045
110 24 1 D0000047
110 25 1 D0000049
110 26 1 D0000051
110 27 1 D0000053
110 28 1 D0000055
110 29 1 D0000057
110 30 1 D0000059
