[GiDlist] mirror_NURBS_SURFACES
Thanasis Makrodimopoulos
Post by Thanasis Makrodimopoulos »
When I mirror a NURBS surface and I generate the mesh
the connectivity is given clockwise (not anti-clockwise).
Do you have any suggestion?
(one solution is to mirror the lines only and define the
surface however sometimes this can be time - consuming)
Thanasis
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050622/8bcbd52d/attachment.htm
You must swap the surface normal: the elements will have the same orientation as the source surface
GiD has some tools about normals: Utilities-DrawNormals-Surfaces
Then select the surfaces, and the normal vector will be drawn.
When drawing surfaces, the contextual menu (click right mouse button) has more contextual options:
-All swapped (change all selection)
-Swap some (change only some selected)
-Swap group (made all selection to be coherent between neighbour elements)
-Sel by normal (select by a direction)
-Color (draw surfaces filled by color: back faces in yellow and front faces in its layer color)
Can use Swap some and select the surface/s to change its orientation to the opposite normal.
Sent: Wednesday, June 22, 2005 11:33 AM
Subject: [GiDlist] mirror_NURBS_SURFACES
Thanasis
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050622/81916c78/attachment.htm
