[GiDlist] Semi-structrured meshes
pablo p del castillo
Post by pablo p del castillo »
hello;
where is this function?:
- Semi-structrured meshes (unstructured in a surface
an a fixed number = of division in a direction)
thanks
______________________________________________
Renovamos el Correo Yahoo!
Nuevos servicios, más seguridad
http://correo.yahoo.es
Hello.
In order to create a semi-structured mesh, must set for example
Meshing-Structured Volumes
Then Select the volume and ONLY assign a number of structured devisions for the lines in the "extrusion" direction.
Then, in general, GiD can automatically detect that must generate a semi-structured mesh of prismas like this.
(if you assigned structured divisions to other lines, can restore the void default values with Meshing-MeshCriteria-Default-Lines)
You can also assign unstructured sizes to the master and/or slave surfaces in the other direction, or set the element type of this surfaces to triangle for ambiguous cases.
Note: this feature is only available in the last 7.5.8b beta version (now only for Windows)
From: "pablo p del castillo" pablodecastillo at yahoo.es
Sent: Wednesday, May 18, 2005 8:15 PM
Subject: [GiDlist] Semi-structrured meshes
hello;
thanks
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050518/19bc5d06/attachment.htm
Name: not available
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050518/19bc5d06/attachment.png
