Hi
I am trying to create batch file which will create
project and than save it. It also saves calculation
file.
The problem is when gid (gid -b filename) is
processing this file it stops at some point saying
(info window):
Last line read 115: in file 'D:\test\batch_template3':
//Yes
The batch file is longer about 160 lines and I do not
know why gid stops processing it.
When I use "Utilities-Graphical-Read Batch Window"
file is processed in its full length so I know it is
working
boris
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
[GiDlist] problem reading batch file
Send us the batch file.
(can send directly to escolano at cimne.upc.edu)
Sent: Wednesday, February 16, 2005 3:02 PM
Subject: [GiDlist] problem reading batch file
Hi
file.
(info window):
//Yes
working
boris
Do You Yahoo!?
Hi
file.
(info window):
//Yes
working
boris
Do You Yahoo!?
Sorry, I found what was the problem.
It was:
escape escape escape escape Meshing Generate
Yes
0.3
escape
And when I put:
0.3
escape
everithing works fine
boris
Do you Yahoo!?
The all-new My Yahoo! - What will yours do?
http://my.yahoo.com
It was:
Yes
0.3
escape
And when I put:
0.3
escape
boris
Do you Yahoo!?
http://my.yahoo.com
[GiDlist] Re: Surface node on volume mesh
Hello, GiD teams
I would like to know whether there is a way to output those surface node coordinates of volume mesh of a model in a single output file or comnbined into the exported GiD (volume) mesh file.
Thanks!
Henry
Post your free ad now! Yahoo! Canada Personals
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050218/cbc169de/attachment.htm
Thanks!
Henry
