[GiDlist] restore line (break up)
Mark Smith
Post by Mark Smith »
Thank you, I look forward to the new feature.
Mean time there is a work around in that I can use utilities:list:lines &
then cut & paste the data into a text editor, remove the unwanted data and
add a header of geometry create point and put escape at the end.
Unfortunately this doesn't always want to work, see attached batch file,
when loaded into GiD it tells me I have an error and stops after reading
line 10 ?
Is there an undocumented format for the batch file?
regards
mark
-----Original Message-----
From: Enrique Escolano [mailto:escolano at cimne.upc.edu]
Sent: 08 February 2005 11:03
Subject: Re: [GiDlist] restore line (break up)
It doesn't exists any funcion to automatically break a curve on this
"special" points (hight curvature changes, etc).
And you don't know the exact curve paremeter to manually divide it.
Maybe for next versions we will remove this "join tangent lines" filter from
the "Collapse" function, and put as a separated funcion.
We will also think about to implement some function to detect and/or divide
curves/surfaces from this special points.
"mailto:mark.smith at linx.co.uk"mark.smith at linx.co.uk
To: "Gidlist (E-mail)" HYPERLINK
"mailto:gidlist at gatxan.cimne.upc.es"gidlist at gatxan.cimne.upc.es
Sent: Friday, February 04, 2005 6:10 PM
Subject: [GiDlist] restore line (break up)
win2000 gid6.3.0b
Hi Gid team
The attached model is a square with rounded corners produced from a square
then performing an arc tangents operation at each corner. I have then
collapsed the lines to give me just 1 line instead of 4 lines and 4 arcs.
Question: is it possible (undo is not an option in my real case) to break
this line back into it's constituent parts again (points lines & arcs)?
if I do an edit nurbs line it shows me all the original points etc how can
I
get them back again?
best regards
mark
No virus found in this outgoing message.
Checked by AVG Anti-Virus.
Version: 7.0.296 / Virus Database: 265.8.5 - Release Date: 03/02/2005
transmitted herewith) is privileged and confidential and is intended for
the
disclosure, reproduction, distribution or other dissemination or use of
this
communication in error, please contact us immediately so that we can
correct
the error.
No virus found in this incoming message.
the error.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050208/787a36c4/attachment.htm
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050208/787a36c4/attachment.obj
Before read this batch, set the general preference (utilities preferences)
create new point: to always
(else, GiD expects user confirmation before create new points very near of other points)
In any case, in general, you cannot reconstruct a line only from his control points.
To: 'gidlist at gatxan.cimne.upc.es'
Sent: Tuesday, February 08, 2005 4:02 PM
Mean time there is a work around in that I can use utilities:list:lines & then cut & paste the data into a text editor, remove the unwanted data and add a header of geometry create point and put escape at the end.
Unfortunately this doesn't always want to work, see attached batch file, when loaded into GiD it tells me I have an error and stops after reading line 10 ?
regards
mark
win2000 gid6.3.0b
Hi Gid team
I
best regards
mark
the
this
correct
the error.
The information contained in this e-mail message (and any attachment transmitted herewith) is privileged and confidential and is intended for the exclusive use of the addressee(s). If you are not an addressee, any disclosure, reproduction, distribution or other dissemination or use of this communication is strictly prohibited. If you have received this communication in error, please contact us immediately so that we can correct the error.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050208/ed64fbb5/attachment.htm
