[GiDlist] restore line (break up)
It doesn't exists any funcion to automatically break a curve on this
"special" points (hight curvature changes, etc).
And you don't know the exact curve paremeter to manually divide it.
Maybe for next versions we will remove this "join tangent lines" filter from
the "Collapse" function, and put as a separated funcion.
We will also think about to implement some function to detect and/or divide
curves/surfaces from this special points.
Sent: Friday, February 04, 2005 6:10 PM
Subject: [GiDlist] restore line (break up)
win2000 gid6.3.0b
Hi Gid team
The attached model is a square with rounded corners produced from a square
then performing an arc tangents operation at each corner. I have then
collapsed the lines to give me just 1 line instead of 4 lines and 4 arcs.
Question: is it possible (undo is not an option in my real case) to break
this line back into it's constituent parts again (points lines & arcs)?
if I do an edit nurbs line it shows me all the original points etc how can
I
get them back again?
best regards
mark
No virus found in this outgoing message.
Checked by AVG Anti-Virus.
Version: 7.0.296 / Virus Database: 265.8.5 - Release Date: 03/02/2005
transmitted herewith) is privileged and confidential and is intended for
the
disclosure, reproduction, distribution or other dissemination or use of
this
communication in error, please contact us immediately so that we can
correct
the error.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050208/53ec3703/attachment.htm
