[GiDlist] template file creation
Sebastian
Post by Sebastian »
Hi
I am using the template file creation feature. Currently I have it
configured that way to let print out the element numbers and the nodes
of those volume elements a volume condition is applied to and of those
surface elements any surface condition is applied to. Now it
occasionally happens that an affected surface element is also part of an
affected volume element. Since surface and volume elements have
different element numbers, it seems there is no way tell that some of
those surface and volume elements belong to each other. However, this
would be important to know for my program. Thanks for any suggestions.
Sebastian
I don't understand well your problem.
Maybe your own program can detect (comparing the node numbers) that a
surface element is the face of a volume element
Sent: Sunday, February 06, 2005 4:48 PM
Subject: [GiDlist] template file creation
Hi
Sebastian
Sebastian
Post by Sebastian »
Yes, I already thought of this, but I wanted to avoid to write such a
algorithm myself. I hoped that each face element "knows" that it is part
of a certain volume element and it would be possible to simply retrieve
the ID of this volume element like
*set var surfaceElem = 0
*Set elems(Quadrilateral)
*loop elems
*set var surfaceElemNum = surfaceElemNum + 1
Face Element *surfaceElemNum -- Volume Element *higherOrderElemNum
*end elems
I guess these volume element IDs are available in GID's tcl scripts,
however, such a command *higherOrderElemNum isn't probably implemented
yet, so that the user could also access to this information.
Cheers
Sebastian
