Hi Enrique,
Thank you for the suggestion, it did not quite work but pointed me in the
right direction. The following solved the problem, add the following line to
the file tclfile-opengl.tcl
package require img::png
mark
-----Original Message-----
From: Enrique Escolano [mailto:escolano at cimne.upc.edu]
Sent: 05 May 2006 20:13
Subject: Re: [GiDlist] windows XP & animation problem
It is a corrected bug, in some cases the img package was not loaded to be
able to read .png images,
It's corrected for 8.x versions, but I'm not sure about how to correct it in
the 7.7.7b version,
maybe you can solve it, by simply adding to the tclfile-opengl.tcl a line
like this:
package require img
to force to load this library
Sent: Friday, May 05, 2006 3:07 PM
Subject: [GiDlist] windows XP & animation problem
GiD 7.7.7b & XP pro
has anyone else experienced problems of not being able to animate on XP
pro
& gid7.7.7b, the animate window is completely greyed out & reports an
error
reading play.png? no problems under windows 2000 sp2.
N.B. no difference found with either software or hardware openGL
acceleration enabled
regards
mark
