Dear all,
I am meshing a 3D voronoi tessellation using GiD. If I try to introduce some spheres in already existing volumes (existing tesselation), the total volume shows as voronoi_tessellation+spheres = NOT TRUE. This is happenning since I am not removing the tessellation volumes and surfaces that are intersecting with the newly added spheres... Is there a way to remove the intersecting portions of original volumes and surfaces.
Thanks very much in advance for your help.
Aman
[GiDlist] Removal of intersecting volumes
[GiDlist] GiD 8.0Rc
Hallo,
I have downloaded GiD 8.0Rc and evaluating. I have the following problems:
1) I am not able to export the GiD drawing to IGES/DXF or any other
format. The program exits with an error message.
2) After pre-processing the data and running FEM program, pressing the
post-processing button works to visualize the data. But after
post-processing if I press the pre-processing button, GiD exits with an
error message.
Could you help?
With regards
Vijayendra
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20060503/bcd5f79e/attachment.htm
error message.
Could you help?
With regards
Vijayendra
