[GiDlist] MAXIMUM NUMBER OF NODES/ELEMENTS
Maik Duwensee
Post by Maik Duwensee »
HI,
I am a (very basic) GiD user since version 5.0 and had recently the
chance to use the Number 7.?? version (test version from the webpage) .
I wanted to create a pretty big triangular mesh. The 'Progress in
meshing' window shows that all of the 80 surfaces I have to be meshed.
But suddenly GiD crashes without any warning whatsoever.
I tried different meshers and played around with the meshing options
(or preferences), with no success.
I am using GiD under WinXP Pro. (32bit)
My questions:
Is there a maximum model size for GID, e.g. a maximum number of nodes
that can be created?
What is the best way to get BIG (2-3 million nodes) meshes?
I would appreciate any help.
Attached please find the model that I was using.
All mesh criteria etc. should be defined. When starting the meshing
process, I have choosen 0.25 for the mesh size to use for surfaces
without definition.
Thanks a lot
Maik
Maik Duwensee
University of California, San Diego
Center for Magnetic Recording Research, 0401
9500 Gilman Drive
La Jolla, CA 92093-0401
maik at talkelab.ucsd.edu
Phone: (858) 534 3175
Fax: (858) 534-2720
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20060124/5f63adad/attachment.obj
Maik Duwensee
Hi again,
I tried to get my mesh with the latest beta version 7.7.5b.
It seems that this version completely ignores the mesh size
definition that I set for certain surfaces although they are
displayed correctly in draw-mesh-sizes-surfaces.
Any solution out there,
thanks a lot
Maik
At 12:01 PM 1/24/2006, you wrote:
HI,
My questions:
nodes that can be created?
without definition.
Thanks a lot
Maik
Maik Duwensee
9500 Gilman Drive
Fax: (858) 534-2720
Maik Duwensee
9500 Gilman Drive
Fax: (858) 534-2720
