Name: not available
Url: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20060117/d15c4f41/attachment.txt
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20060117/d15c4f41/attachment.htm
[GiDlist] Becames an empty array
You must declare this variable array 'ProblemTypePriv' as global for this procedure
global ProblemTypePriv
Sent: Tuesday, January 17, 2006 3:27 PM
Subject: [GiDlist] Becames an empty array
Hi GID team!
I have this procedure.
proc FunctionAdd2 { wtext parent} {
global inum
set resauxp [.central.s info conditions PointLoad mesh]
if {$resauxp != ""} {
set ProbemTypePriv(pointassign) ""
#lappend ProbemTypePriv(pointassign) ""
foreach i $resauxp {
set point [lindex $i 15]
$wtext insert end $point
if {$inum!= 1} {
if {[lsearch $ProblemTypePriv(pointassign) $point] == -1} {
lappend ProblemTypePriv(pointassign) $point
incr inum
} else {
incr inum
But i have one problem, everytime this procedure is called,
doesn't works. This variable don't became empty.
Can you help me to solve this?
Thanks.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20060117/7c7e0a2c/attachment.htm
Hi GID team!
global inum
if {$inum!= 1} {
incr inum
} else {
incr inum
Thanks.
Name: not available
Url: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20060117/2be2a816/attachment.txt
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20060117/2be2a816/attachment.htm
Name: not available
Name: not available
Url: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20060117/d2a0580f/attachment.txt
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20060117/d2a0580f/attachment.htm
Name: not available
