[GiDlist] Format of batch file (*.bch) for arcline and NURBS
Furui, Kenji
[GiDlist] 3D meshing problem with inner surface and overlap
Post by Furui, Kenji »
When I open a postprocess data file (.bin file), Info Window shows the following message "Jacobi: 20 rotations are not enough". Could you please help me understand what it means? Also should it cause any potential problem??? I'm using GiDx64, ver 10.0.5.
[cid:325060213 at 13052011-09D7]
Kenji Furui, Ph.D.
ConocoPhillips Company
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20110513/5e59c104/attachment-0001.htm
Type: image/jpeg
Desc: Outlook.jpg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20110513/5e59c104/attachment-0001.jpg
3D meshing problem with inner surface and overlapThis message is raised probably when calculating the eigenvalues/eigenvectors of the strain/stress tensor, to draw main components and its vector directions.
(a Jacobi-based algorithm is used to calculate them)
The only problem is that maybe this eigenvectors are not calculated with enougth precision in some element.
Off course this message is not expected to be shown to final users like you in a normal situation,
maybe there is some problem with your results or your mesh (some degenerated element or wrong numerical result values)
Could you send me your example, including results? (directly to escolano at cimne.upc.edu instead the GidList)
To: 'gidlist at listas.cimne.upc.edu'
Sent: Friday, May 13, 2011 3:08 PM
Subject: Re: [GiDlist] 3D meshing problem with inner surface and overlap
Kenji Furui, Ph.D.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20110513/260c32fc/attachment-0001.htm
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20110513/260c32fc/attachment-0001.jpeg
Furui, Kenji
Enrique,
Thanks for your prompt response. I'll check my mesh and numerical results again. I've uploaded the postprocess file at the following ftp server:
SERVER NAME: b2bftp.conocophillips.com
LOGIN ACCOUNT: copanon
PASSWORD: P66ypwty
URL: ftp://copanon@b2bftp.conocophillips.com
ftp://copanon@b2bftp.conocophillips.com/
My simulation file is located under "GiD_Enrique" folder.
Kenji Furui, Ph.D.
From: gidlist-bounces at listas.cimne.upc.edu [mailto:gidlist-bounces at listas.cimne.upc.edu] On Behalf Of Enrique Escolano
Sent: Friday, May 13, 2011 9:07 AM
From: Furui, Kenjimailto:Kenji.Furui at conocophillips.com
To: 'gidlist at listas.cimne.upc.edu'mailto:'gidlist at listas.cimne.upc.edu'
[cid:898445914 at 13052011-09DE]
Kenji Furui, Ph.D.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20110513/0b3fba35/attachment-0001.htm
Type: image/jpeg
Desc: Outlook.jpg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20110513/0b3fba35/attachment-0001.jpg
3D meshing problem with inner surface and overlapI have tried to repeat the problem, but I am unable to do it.
I have used the related 10.0.5 Win x64 version, load your SAND3D.GiD.bin file in postprocess, and shown contour fill and display vectors of main stresses, etc, doing an animation on all time steps, but nothing wrong happened. The related Jacobi: 20 rotations are not enough message was not shown.
What are you exactly doing to have this message? Try to repeat it using this SAND3D.GiD.bin file.
(maybe initially you are reading other kind of files, like ASCII ones, and then GiD is using other internal procedures)
Sent: Friday, May 13, 2011 5:02 PM
Enrique,
PASSWORD: P66ypwty
Kenji Furui, Ph.D.
Kenji Furui, Ph.D.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20110513/8dc624f2/attachment-0001.htm
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20110513/8dc624f2/attachment-0001.jpeg
Furui, Kenji
Enrique,
Sorry, It seems like I placed a wrong file in the ftp site. I've just updated the bin file (Size: 115 MB). Could you please try it again? Kenji
Sent: Friday, May 13, 2011 11:43 AM
Enrique,
PASSWORD: P66ypwty
Kenji Furui, Ph.D.
[cid:976560617 at 13052011-09E5]
Kenji Furui, Ph.D.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20110513/c40ce874/attachment-0001.htm
Type: image/jpeg
Desc: Outlook.jpg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20110513/c40ce874/attachment-0001.jpg
3D meshing problem with inner surface and overlapDear Kenji,
The problem is that there are some wrong values in the "Stress" result of the element number 1827 in the last time step=30
a few values are 'not a number'.
Then appear after the error message when calculating main stresses.
Check what's happening with the solver for this time step and element.
Sent: Friday, May 13, 2011 7:09 PM
Enrique,
Enrique,
PASSWORD: P66ypwty
Kenji Furui, Ph.D.
Kenji Furui, Ph.D.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20110516/a7e3248f/attachment-0001.htm
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20110516/a7e3248f/attachment-0001.jpeg
Furui, Kenji
Thanks a lot, Enrique. This is a big help for me. It looks the nonlinear calculation didn't converge at the step 30 causing this problem.
Kenji Furui, Ph.D.
Sent: Monday, May 16, 2011 8:25 AM
Dear Kenji,
Enrique,
From: gidlist-bounces at listas.cimne.upc.edumailto:gidlist-bounces at listas.cimne.upc.edu [mailto:gidlist-bounces at listas.cimne.upc.edu] On Behalf Of Enrique Escolano
To: gidlist at listas.cimne.upc.edumailto:gidlist at listas.cimne.upc.edu
Enrique,
PASSWORD: P66ypwty
Kenji Furui, Ph.D.
[cid:296013713 at 16052011-000C]
Kenji Furui, Ph.D.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20110516/2bb6866f/attachment-0001.htm
Type: image/jpeg
Desc: Outlook.jpg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20110516/2bb6866f/attachment-0001.jpg
