[GiDlist] Sequential Node Numbering
[GiDlist] duplicating nodes in GID
The Linux versions 12.0.2 and 12.1.1d x32 and x66 are also available now for download.
Your current licence 12.x is valid for all GiD 12.x versions, official and developers.
And you can install as much GiD versions as you want, each one is installed in a different folder.
Enviado el: lunes, 27 de octubre de 2014 16:49
Asunto: Re: [GiDlist] duplicating nodes in GID
I am using the linux version. My question is, can I just install it again with my current licence when it's available (and would a note be placed on the website http://www.gidhome.com/download when it is updated)?
thanks!
On Mon, Oct 27, 2014 at 4:33 AM, Enrique Escolano escolano at cimne.upc.edu wrote:
If you are using Windows platform you are lucky, you can download now two fixed versions:
the 12.0.2 official version, and the 12.1.1d developer version. Both are available for x32 and x64 bits
I recommend you to try the developer version, it has this fixed bug and new features, like STEP format export.
About the Linux version and the first Mac OS X GiD 12 version they will be available soon (maybe today or in few days)
Enviado el: sábado, 25 de octubre de 2014 9:20
Yes, the duplicate node feature works for the version you mentioned. Would it be possible to have some kind of timeline when the bug would be fixed in v12? Also if not, I have a full 1 year version v12, is it possible to convert this into the 10.0.9 version in which this feature works? As the number of nodes are restricted to only 1000 and surfaces to 25 in the evaluation version.
Thanks!
On Thursday, October 9, 2014, Enrique Escolano escolano at cimne.upc.edu wrote:
Without using any special ‘Duplicate nodes’ tool you must manually duplicate the geometric entities to have two surfaces (and its lines and points) on each side of the crack, and then each one will generate its nodes (but these nodes won’t be exactly in the same amount and location for both entities).
But it is easier to have only a single surface (and its lines and points) and apply the duplicate nodes mesh condition to left this task to the mesher.
I recommend you to temporary install also the 10.0.9 version, it takes five minutes, until the new 12 fixed version will be fixed
Enviado el: jueves, 9 de octubre de 2014 19:35
Thanks for letting me know about the bug. Just one question- since I can't duplicate nodes, there is no way to represent a crack in the latest GID version, right? Or is there can be some other way we can implement this.
Thank you
Amit
On Wed, Oct 8, 2014 at 7:54 AM, Enrique Escolano escolano at cimne.upc.edu wrote:
You are right, duplicate nodes is broken in current GiD versions, and nodes become not duplicated!!
Temporary you can download and try the version GiD 10.0.9 (can get a free trial password in the web), with this version this tool already works.
We will fix the bug for next GiD 12 versions.
Enviado el: viernes, 3 de octubre de 2014 14:58
Asunto: [GiDlist] duplicating nodes in GID
I am having issues in created duplicate nodes at a given surface. I having this kind of geometry-
Inline image 1
which is basically four small volumes. I'm trying to duplicate nodes among a common sharing surface (to represent a crack surface) but GID is not creating duplicate nodes. For example, in the figure, if I create a mesh with one cell along each edge (structured mesh option) it yeilds 18 nodes (9 at top and 9 at bottom) but it should have given me 4 extra nodes (i.e total of 22 nodes) if I chose duplicate nodes. Any leads why this might be?
Amit
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141027/efdbdb00/attachment-0001.htm
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141027/efdbdb00/attachment-0001.jpeg
