Node Renumbering
crised
Node Renumbering
Post by crised »
Hello! I wonder if it is possible to change node numbering once mesh is generated. I've tried to go to Utilities->Renumber but node numbers do not change.
Thanks in Advance
Re: Node Renumbering
In geometry view Utilities->Renumber try to renumber the geometrical entities avoiding holes in its numeration.
If there are no jumps in the numeration then ids won't change.
In mesh view Utilities->Renumber try to renumber mesh entities. entities (nodes and elements) try to renumber avoiding holes,
and also the nodes are renumbered with another extra ordering criteria, depending on the GiD Variable 'RenumberMethod' value
http://www.gidhome.com/documents/refere ... rocessing)
crised
Post by crised »
How can I change the value of this variable?
crised
Post by crised »
Thank you very much! It has been very useful for me! Just one more question. Is it possible to start node numbering in number one?
GiD entity ids already start by 1 at leas at level user (some scripting level commands could start by 0)
Dimmerman
Post by Dimmerman »
escolano wrote:In geometry view Utilities->Renumber try to renumber the geometrical entities avoiding holes in its numeration.
Thanks escolano. That helped!
