Mesh Data File
crised
Mesh Data File
Post by crised »
Hi! I've written a ASCII project in order to export a mesh I had generated with GiD. I can't find information about the structure of the generated .mesh file. Where can I find this information? Only appears the structure of a post processing mesh in the customization manual. Is it the same?
Re: Mesh Data File
The format of this ASCII project mesh file is not documented , but probably it is easy to be deducted because is ASCII (could be seen with a text editor) and it is simple.
You can also export the mesh with Files->Export->GiD mesh... that has the same syntax as the postprocess ASCII mesh that you have seen in the customization manual.
