No results found: definitions for 2 gauss points read.
Moderator: CODE_BRIGHT Team
rawatamm
Post by rawatamm »
Dear All Users,
I have to model a column experiment set up with simple hydro mechanical coupling for axis symmetry case. There is an air gap of about 1.5 mm between soil sample and experimental device. I have modelled the entire test set up. During calculation, there is some error, saying No results found: definitions for 2 gauss points read.
Can anyone help me on this issue.
Abhishek Rawat
Column_TESTAirGAP.zip
(201.79 KiB) Downloaded 430 times
Re: No results found: definitions for 2 gauss points read.
Having a look to the file 'Column_TESTAirGAP_gen.out' the resolutin is not converging.
It try to automatically reduce the time step but it is not working (the appear NaN values) , then is doesn't write any result in the .pos.res file.
I am not user of Code_brigth, maybe your initial time step is too big, of some property has wrong values.
