get material name from *MatNum
kstn
Post by kstn »
Hello
Is there a way to get the material name from *MatNum in *loop material ?
Consider the loop
*loop materials
        Material *MatNum is assigned DENSITY = *MatProp(Density,real)
        Material *MatNum has name ???
*end materials
The problem is that the model has many materials and each portion is given a material name (which is copied from an existing one). With the somehow random *MatNum assigned, it's not possible to know which material number is assigned to which name in the simulation script.
Giang
Re: get material name from *MatNum
the 0-index field return the material's name
*MatProp(0)
