I've found strange problem please advice what I did wrong.
I want save the post-process results in higher resolution that just make a print screen.
1. I've setup "page and capture settings" and press "snapshot" button.
2. In a snapshot file i see that GiD render wrongly legend if i set landscape orientation and resolution higher than 550dpi.
When i use resolution 600dpi program cut the legend (higher value) not rendered in a snapshot, for higher resolution legend not rendered correctly at all.
3. What i need to do to omit such problems?
