changing colors of layers (preprocessor) -> crash
sebastian_munich
Post by sebastian_munich »
Dear developers,
the headline describes my problem pretty much. As soon as I close the "select & display style" window after changing the color of a layer in the preprocessor GiD crashes.
GiD version: 11.0.8
OS: windows 8.1.
Thank you in advance!
Re: changing colors of layers (preprocessor) -> crash
It seems a problem of OpenGL with your graphic card or driver.
Try to use GiD with OpenGL by software (Safe visualization mode)
Menu: Utilities->Preferences... Graphical - Safe visualization mode
and press Accept (GiD must be restarted to apply this change)
You can try to use the last 11.1.9d developer version, maybe this problem has been fixed in this version
(the password of your 11.0.8 version is valid also for this version)
http://www.gidhome.com/download/developer-versions
sebastian_munich
Thank you for your quick response!
The new developer version solved the problem. (changing settings didn't)
