just a very stupid question:
I would like to display the grid of a 2d result (4 noded quadrilaterals) as shown in the first attachment. I was able to do this in older version of GiD, but with the latest ones I can only see the boundary.
I use view style: "Body Lines" and the option "interior of Set ... will be drawn".
Where is the option to turn on the grid??
Malte
Display grid in 2D
Display grid in 2D
- GiD.PNG (39.79 KiB) Viewed 8242 times
- grid.png (71.64 KiB) Viewed 8242 times
Re: Display grid in 2D
Hi Malte,
With these configuration you should be able to see the inner lines. It looks like a bug.
Could you please paste the information that you get in Help->About->More ?
Are you able to see the lines if you rotate the model?
you are right: I can see the grid after rotating and also when selecting isometric. Only for "Plane XY (Original)" the grid is missing.
Here is my system information:
GiD internal version: 12.0 ( 64 bits)
Operating system: 'amd64' 'windows' 'Windows NT' '6.2'
Tcl8.6.1 Tk8.6(8.6.1)
OpenGL 4.0.0 - Build 10.18.10.3643 on Intel(R) HD Graphics 4000
GLEW 1.9.0
Togl 1.7: asked for an accelerated renderer,
Asked Pixelformat description ( 5):
Hardware accelerated (ICD) implementation, PixelFormat 5,
DoubleBuffer: yes,
StereoBuffer,
RGBA, Composition enabled (Vista), Draw to Window, OpenGL support,
Using 24 Color bits: 8 red, 8 green, 8 blue and 8 alpha,
Using 0 Accumulation bits: 0 red, 0 green, 0 blue and 0 alpha,
Using 32 Depth bits and 8 StencilBits
0 Auxiliary buffers
00 underlay ( 0x-fx) and overlay ( x0-xf) planes
Gotten Pixelformat description ( 5):
DoubleBuffer: yes exchange,
Using 32 Color bits: 8 red, 8 green, 8 blue and 8 alpha,
Using 64 Accumulation bits: 16 red, 16 green, 16 blue and 16 alpha,
Using 24 Depth bits and 8 StencilBits
0 Auxiliary buffers
OpenGl:
VENDOR: Intel
RENDERER: {Intel(R) HD Graphics 4000}
VERSION: {4.0.0 - Build 10.18.10.3643}
GLSL version: {4.00 - Build 10.18.10.3643}
DISPLAY INFORMATION: {bits red 8, green 8, blue 8, alpha 8, depth 24, stencil 8, stereo no.}
LIMITS: {
Max Texture Size: 16384
Max Elements Indices: 1048576
Max Elements Vertices: 1048576
Max 3D Texture Size: 2048
Max Cube Map Texture Size: 16384
Available video memory size: 32 MBytes
Maximum working number of elements: 546 K
EXTENSIONS: {
GL_3DFX_texture_compression_FXT1
GL_ARB_arrays_of_arrays
GL_ARB_base_instance
GL_ARB_blend_func_extended
GL_ARB_buffer_storage
GL_ARB_color_buffer_float
GL_ARB_compatibility
GL_ARB_compressed_texture_pixel_storage
GL_ARB_conservative_depth
GL_ARB_copy_buffer
GL_ARB_debug_output
GL_ARB_depth_buffer_float
GL_ARB_depth_clamp
GL_ARB_depth_texture
GL_ARB_draw_buffers
GL_ARB_draw_buffers_blend
GL_ARB_draw_elements_base_vertex
GL_ARB_draw_indirect
GL_ARB_draw_instanced
GL_ARB_ES2_compatibility
GL_ARB_explicit_attrib_location
GL_ARB_fragment_coord_conventions
GL_ARB_fragment_program
GL_ARB_fragment_program_shadow
GL_ARB_fragment_shader
GL_ARB_framebuffer_no_attachments
GL_ARB_framebuffer_object
GL_ARB_framebuffer_sRGB
GL_ARB_geometry_shader4
GL_ARB_get_program_binary
GL_ARB_gpu_shader5
GL_ARB_gpu_shader_fp64
GL_ARB_half_float_pixel
GL_ARB_half_float_vertex
GL_ARB_instanced_arrays
GL_ARB_internalformat_query
GL_ARB_internalformat_query2
GL_ARB_map_buffer_alignment
GL_ARB_map_buffer_range
GL_ARB_multi_draw_indirect
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_occlusion_query
GL_ARB_occlusion_query2
GL_ARB_pixel_buffer_object
GL_ARB_point_parameters
GL_ARB_point_sprite
GL_ARB_program_interface_query
GL_ARB_provoking_vertex
GL_ARB_robustness
GL_ARB_sample_shading
GL_ARB_sampler_objects
GL_ARB_seamless_cube_map
GL_ARB_separate_shader_objects
GL_ARB_shader_atomic_counters
GL_ARB_shader_bit_encoding
GL_ARB_shader_objects
GL_ARB_shader_precision
GL_ARB_shader_subroutine
GL_ARB_shading_language_100
GL_ARB_shading_language_420pack
GL_ARB_shading_language_packing
GL_ARB_shadow
GL_ARB_stencil_texturing
GL_ARB_sync
GL_ARB_tessellation_shader
GL_ARB_texture_border_clamp
GL_ARB_texture_buffer_object_rgb32
GL_ARB_texture_buffer_range
GL_ARB_texture_compression
GL_ARB_texture_compression_bptc
GL_ARB_texture_compression_rgtc
GL_ARB_texture_cube_map
GL_ARB_texture_cube_map_array
GL_ARB_texture_env_add
GL_ARB_texture_env_combine
GL_ARB_texture_env_crossbar
GL_ARB_texture_env_dot3
GL_ARB_texture_float
GL_ARB_texture_gather
GL_ARB_texture_multisample
GL_ARB_texture_non_power_of_two
GL_ARB_texture_query_lod
GL_ARB_texture_rectangle
GL_ARB_texture_rg
GL_ARB_texture_rgb10_a2ui
GL_ARB_texture_storage
GL_ARB_texture_storage_multisample
GL_ARB_texture_swizzle
GL_ARB_timer_query
GL_ARB_transform_feedback2
GL_ARB_transform_feedback3
GL_ARB_transform_feedback_instanced
GL_ARB_transpose_matrix
GL_ARB_uniform_buffer_object
GL_ARB_vertex_array_bgra
GL_ARB_vertex_array_object
GL_ARB_vertex_attrib_64bit
GL_ARB_vertex_attrib_binding
GL_ARB_vertex_buffer_object
GL_ARB_vertex_program
GL_ARB_vertex_shader
GL_ARB_vertex_type_2_10_10_10_rev
GL_ARB_viewport_array
GL_ARB_window_pos
GL_ATI_separate_stencil
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_blend_color
GL_EXT_blend_equation_separate
GL_EXT_blend_func_separate
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_clip_volume_hint
GL_EXT_compiled_vertex_array
GL_EXT_draw_buffers2
GL_EXT_draw_range_elements
GL_EXT_fog_coord
GL_EXT_framebuffer_blit
GL_EXT_framebuffer_multisample
GL_EXT_framebuffer_object
GL_EXT_geometry_shader4
GL_EXT_gpu_program_parameters
GL_EXT_gpu_shader4
GL_EXT_multi_draw_arrays
GL_EXT_packed_depth_stencil
GL_EXT_packed_float
GL_EXT_packed_pixels
GL_EXT_rescale_normal
GL_EXT_secondary_color
GL_EXT_separate_specular_color
GL_EXT_shader_integer_mix
GL_EXT_shadow_funcs
GL_EXT_stencil_two_side
GL_EXT_stencil_wrap
GL_EXT_texture3D
GL_EXT_texture_array
GL_EXT_texture_buffer
GL_EXT_texture_compression_s3tc
GL_EXT_texture_edge_clamp
GL_EXT_texture_env_add
GL_EXT_texture_env_combine
GL_EXT_texture_filter_anisotropic
GL_EXT_texture_integer
GL_EXT_texture_lod_bias
GL_EXT_texture_rectangle
GL_EXT_texture_shared_exponent
GL_EXT_texture_snorm
GL_EXT_texture_sRGB
GL_EXT_texture_sRGB_decode
GL_EXT_texture_storage
GL_EXT_texture_swizzle
GL_EXT_transform_feedback
GL_IBM_texture_mirrored_repeat
GL_INTEL_map_texture
GL_INTEL_performance_queries
GL_KHR_blend_equation_advanced
GL_KHR_debug
GL_NV_blend_square
GL_NV_conditional_render
GL_NV_primitive_restart
GL_NV_texgen_reflection
GL_SGIS_generate_mipmap
GL_SGIS_texture_edge_clamp
GL_SGIS_texture_lod
GL_SUN_multi_draw_arrays
GL_WIN_swap_hint
GLX::
SERVER:
OVERLAY: 0
OVERLAY IN MENU: 0
Malte
GLEW 1.9.0
DoubleBuffer: yes,
StereoBuffer,
0 Auxiliary buffers
0 Auxiliary buffers
OpenGl:
VENDOR: Intel
LIMITS: {
EXTENSIONS: {
GL_ARB_copy_buffer
GL_ARB_debug_output
GL_ARB_depth_clamp
GL_ARB_draw_buffers
GL_ARB_gpu_shader5
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_point_sprite
GL_ARB_robustness
GL_ARB_shadow
GL_ARB_sync
GL_ARB_texture_rg
GL_ARB_timer_query
GL_ARB_window_pos
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_blend_color
GL_EXT_blend_minmax
GL_EXT_fog_coord
GL_EXT_gpu_shader4
GL_EXT_packed_float
GL_EXT_shadow_funcs
GL_EXT_stencil_wrap
GL_EXT_texture3D
GL_EXT_texture_sRGB
GL_KHR_debug
GL_NV_blend_square
GL_SGIS_texture_lod
GL_WIN_swap_hint
GLX::
SERVER:
OVERLAY: 0
OVERLAY IN MENU: 0
Malte
Ok, it looks like a bug that we found in computers with an integrated Intel graphic card.
We will fix it for the next versions.
For the moment you can try to change the OpenGL configuration to "Safe visualization mode" in preferences window in Graphical->System branch.
Thanks for reporting!
corrected the problem for the next Oficial and Developer versions.
This problem also arises in Linux with Ubuntu's native drivers for AMD Radeon cards ( Gallium+AMD Radeon driver).
thanks for the report,
