[GiDlist] legend size and title
Gangjin Li
Post by Gangjin Li »
Hi, Gid team,
How can I enlarge the legend box and change its title when producing an
animation? It seems I can change the legend title under the menu
Options--Legends, but once I start animating, the title just goes back to
the original name. And I fail to find a way to increase the size of the
legend. Could you please help me out? Thanks.
Gangjin Li
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141014/c6a316d1/attachment.htm
The size can’t be set, It automatically is adapted to its text.
About its content, try also from Utilities-Tools-Comments
You can disable the automatic title and set the text you want.
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Gangjin Li
Enviado el: miércoles, 15 de octubre de 2014 1:45
Asunto: [GiDlist] legend size and title
Hi, Gid team,
Gangjin Li
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141015/965fe9e4/attachment.htm
Viahn Parazee
[GiDlist] GiDlist Digest, Vol 51, Issue 16
Post by Viahn Parazee »
Thank you so much. Sorted out.
Subject: GiDlist Digest, Vol 51, Issue 16
Date: Mon, 13 Oct 2014 12:00:01 +0200
Send GiDlist mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body 'help' to
gidlist-request at listas.cimne.upc.edu
You can reach the person managing the list at
gidlist-owner at listas.cimne.upc.edu
When replying, please edit your Subject line so it is more specific
than "Re: Contents of GiDlist digest..."
Today's Topics:
1. Re: How to assign a gravity load (9810mm/s^s) in GiD
(Enrique Escolano)
Message: 1
Date: Mon, 13 Oct 2014 10:54:18 +0200
Subject: Re: [GiDlist] How to assign a gravity load (9810mm/s^s) in
GiD
Message-ID: 004f01cfe6c3$4630fae0$d292f0a0$@cimne.upc.edu
Content-Type: text/plain; charset="us-ascii"
This kind of data must be defined by the problemtype,
GiD don't define any material or its properties like density, young modulus,
etc. It is the problemtype who define the conditions like 'load' and
material
properties that are needed for its simulation.
Which problemtype are you using? CompassFEM's RamSolid maybe?
Then the density is defined in the material and then to consider the gravity
load must assign the 'self weigth load to volumes (and then its material
density is used)
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Viahn Parazee
Enviado el: viernes, 10 de octubre de 2014 13:53
Asunto: [GiDlist] How to assign a gravity load (9810mm/s^s) in GiD
Hi
I want to apply a gravity load to my structure. Does GiD take the density
that I have specified in the material properties into account or do I have
to assign a body load consisting of the unit weight of the material?
Thank you
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141013/b231ba01/attachment.html
End of GiDlist Digest, Vol 51, Issue 16
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141016/b04350e8/attachment.htm
Viahn Parazee
[GiDlist] Particle is not a member of any element
Hi, GiD team,
I am getting the error stated in the subject line and have tried remeshing a few times. When I signal the particle that the error is referring to it appears to be within one of the tetrahedral elements. Any ideas on how I can go about solving this problem?
Furthermore, when assigning hexahedra element types to the structure, it informs me that one of the volumes can only be meshed with the tetrahedra element type. Is there any way around this?
Thank you for your time.
Viahn Parazee
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141016/172c6d09/attachment.htm
You must explain a little better your case, and probably attach the GiD
example,
I don't know who is raising the message "Particle is not a member of any
element".
Is this message exact? (I didn't found the message anywhere in GiD)!!!
Which kind of mesh are you trying to generate? (e.g. spheres, tetraedra),
and which mesher are you setting in the preferences-meshing window?
About meshing hexahedra, GiD can't generate unstructured hexas !!
it is only possible to generate them for structured meshes (the volume must
be topologically a cube with exactly 6 boundary surfaces,
or semi-structured surfaces, for extrusion volumes (two opposite tops joined
by extruded lateral surfaces of exactly 4 sides)
Enviado el: jueves, 16 de octubre de 2014 14:00
Asunto: [GiDlist] Particle is not a member of any element
Hi, GiD team,
Viahn Parazee
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141016/54dcddce/attachment.htm
