Hi, I have generated a GID geometry (*.geo) file with an external program.
The file was correctly loaded by GID (I am running version 5.0 p47 and 6.0
beta 2, professional edition) and I can generate a FE mesh (triangles).
However when I try to cancel the mesh (Meshing-Cancel Mesh) the program
(GID) hangs badly. The same problem happens with both GID versions I
mentioned, but does not happen with other files. I loaded the initial *.geo
file and saved it again (even changing its name) from within GID hoping the
problem was a format problem but it still hangs GID. It also hangs GID when
trying to save the file AFTER generating the FE mesh (but not before). I
attach to this e-mail the *.geo file (as an ascii file) as saved by GID.
Thank you very much,
Andrea Assanelli
Senior Research Engineer
CINI/FUDETEC
Buenos Aires
ARGENTINA
test002.geo
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20000810/c5120cdd/attachment.obj
[ GiDlist ] Problems with a mesh
Before generate the mesh or save the problem, try to repair the geometry
(Utilities-Repair).
-----Original Message-----
[mailto:owner-gid at gatxan.cimne.upc.es]On Behalf Of ASSANELLI Andrea CINI
Sent: Thursday, August 10, 2000 8:33 PM
To: 'gidlist at gatxan.cimne.upc.es'
Subject: [ GiDlist ] Problems with a mesh
Andrea Assanelli
CINI/FUDETEC
Buenos Aires
ARGENTINA
test002.geo
(Utilities-Repair).
Andrea Assanelli
CINI/FUDETEC
Buenos Aires
ARGENTINA
test002.geo
