Hi everyone,
I assign some conditions with some values, but whe iI read the file **.cnd,in
the field VALUE there is default value.Why?
And then, when I Unassign all condition i think that file **.cnd should
be erase, but it is there with the previous value.
Thanks in advance!
Calogero.
[GiDlist] Conditions
The file *.cnd contain the template of the condition (questions and default
values),
but not contain the instances of this template (the values and assigned
entities).
This condition instances are saved in the *.lin binary file.
To: "GIDLIST" gidlist at gatxan.cimne.upc.es
Sent: Wednesday, July 30, 2003 10:42 AM
Subject: [GiDlist] Conditions
Hi everyone,
**.cnd,in
Thanks in advance!
Calogero.
values),
entities).
Hi everyone,
**.cnd,in
Thanks in advance!
Calogero.
[GiDlist] How to include different types of .res files
Hi GiD Team and all
I would like to display the Outputs in .res file in
different types of Analysis. For example: I have
output in "Linear Static case" and "Non Linear with
Time step" "Influence line" and so forth..
How can I Include these results in PostProcessing
file??
Can we use the command "include"? if so how? Please
give small example.
Best Regards
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
file??
give small example.
Best Regards
Do you Yahoo!?
You can write these results in the same .res file:
GiD Post Results File 1.0
Result "damage" "Linear Static case" 0.0 Scalar OnNodes
Result "damage evolution" "Non linear with time step" 1.0 Scalar OnNodes
and so on.
You can alo use "include", like this:
include "My Other Results File"
include "another file"
and so on.
VSayako Willy wrote:
Hi GiD Team and all
file??
give small example.
Best Regards
Do you Yahoo!?
and so on.
and so on.
Hi GiD Team and all
file??
give small example.
Best Regards
Do you Yahoo!?
Many thanks Miguel
Please take a look my attached file and Please
advice what's wrong in the file format. I also
included the OldFormat of the .res file. Both are not
working properly
Best regards.
--- "Miguel A. de Riera Pasenau" miguel at cimne.upc.es
OnNodes
and so on.
and so on.
Hi GiD Team and all
file in
with
file??
Please
give small example.
Best Regards
Do you Yahoo!?
design software
Do you Yahoo!?
Desc: BridgeTest.gid.zip
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030801/c6c1aa19/attachment.bin
working properly
Best regards.
OnNodes
and so on.
and so on.
Hi GiD Team and all
file in
with
file??
Please
give small example.
Best Regards
Do you Yahoo!?
design software
Do you Yahoo!?
just add a new-line after the last 'end values' line.
Many thanks Miguel
working properly
Best regards.
OnNodes
and so on.
and so on.
Hi GiD Team and all
file in
with
file??
Please
give small example.
Best Regards
Do you Yahoo!?
design software
Do you Yahoo!?
BridgeTest.gid.zip Type: Zip Compressed Data (application/x-zip-compressed)
Encoding: base64
Description: BridgeTest.gid.zip
Many thanks Miguel
working properly
Best regards.
OnNodes
and so on.
and so on.
Hi GiD Team and all
file in
with
file??
Please
give small example.
Best Regards
Do you Yahoo!?
design software
Do you Yahoo!?
Encoding: base64
