[GiDlist] Potential problems with results on Gauss Points wi
Guy HUBERT
Post by Guy HUBERT »
Hello
It seems there is an interpolation problem with this exemple on
Gid 7.2 for Windows.
To see the problem,
Load .res
View-Read and select bar.vpt
Display with color-Fill SIEF_R g_SIXX (g is for gauss)
If you labeled elements results, you will see that results for elements
1 and 2 are symetric. This is not the case in the colored fill picture
and value seems very strange.
You can view the right distribution with SIEF_R n_SIXX (on nodes elements by
elements) or with SIEF_R SIXX (on nodes)
________________________________________________________________
Guy HUBERT Mailto:hubert at deltacad.fr
Tel direct : +33 (0)3 44 23 52 99 mobile: 06 76 80 03 42
DeltaCAD
Centre de Transfert - 66 Avenue de Landshut
60200 COMPIEGNE (FRANCE)
Tel : +33 (0)3 44 23 46 54 - Fax : +33 (0)3 44 23 46 31
Web : http://www.deltacad.fr
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030728/c17bb00b/attachment.obj
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030728/c17bb00b/attachment-0001.obj
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030728/c17bb00b/attachment-0002.obj
ieea
[GiDlist] Create Text
Post by ieea »
Dear All,
I wish create a text automatically from a Tcl command.
I suppose I should use the GID command "Utilities Dimension Create
Text", but I don't know how
to indicate the text that will appear.
If somebody has ever used this command in a Tcl script I will thank him
in advance.
G.W.R. Geis
the GiD command to create a text is:
escape escape escape utilities dimension create text "the text" leftmouse x
y
x y are the relative screen coordinates from a range -1.0 to 1.0. The screen
center is (0, 0)
Note: the current GiD version expects interactively the text input: To avoid
the text input window, must set
temporary the variable UseMoreWindows to 0 (Utilities Variables
UseMoreWindows 0) and after restore
to the previous value (to get the value must use .central.s info variables
UseMoreWindows)
To: "GID list" GIDlist at gatxan.cimne.upc.es
Sent: Sunday, July 28, 2002 2:41 PM
Subject: [GiDlist] Create Text
Dear All,
in advance.
G.W.R. Geis
ieea
Post by ieea »
Thank you Enrique
One more time, it's running good now.
G.W.R. Geis
y
center is (0, 0)
UseMoreWindows)
Dear All,
in advance.
G.W.R. Geis
Miguel A. de Riera Pasenau
Post by Miguel A. de Riera Pasenau »
yes, this problem was corrected with version GiD 7.4.2b.
but with this version you can not read your saved views
(some more parameters has been added).
the next beta version, which will be available in a couple
of days, will read these views.
Guy HUBERT wrote:
Hello
To see the problem,
Load .res
DeltaCAD
bar.vpt Type: unspecified type (application/octet-stream)
Encoding: quoted-printable
bar_H8.res Type: unspecified type (application/octet-stream)
Encoding: 7bit
bar_H8.msh Type: unspecified type (application/octet-stream)
Encoding: 7bit
