[GiDlist] The NASA metallic almond
Hi! My aim is to create "the NASA metallic almond", which is a parametric
surface. Theoretically i cold not do it by GiD; is there a particular method
to do it?
Gero
to do it?
Gero
You can create an approximate surface:
for example, create a set of curves u=constant (can use
Geometry-Create-Parametric Line)
and create a nurbsurface "By parallel lines" with this set of curves.
(Geometry-Create-Nurbs Surface-Parallel lines)
You can also create it externally with some CAD, and import it, using IGES
or another intechange format.
To: "GIDLIST" gidlist at gatxan.cimne.upc.es
Sent: Thursday, April 24, 2003 10:52 AM
Subject: [GiDlist] The NASA metallic almond
method
to do it?
Gero
method
to do it?
Gero
[GiDlist] Can I create structured mesh with only points?
Dear GiD Team,
I need to transfer results from finite difference (finite volume) to GiD post.The results only provide at node and I require no element to make such computations. It's more convenient to transfer these results to node directly. Can I create a structured mesh with only points instead of hex elements? I tried but it failed,and finally I got unstructured mesh.
Bests,
Adisorn
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030425/f056ac12/attachment.htm
Bests,
Adisorn
if you want only to define the results over points you'll need 'point elements'
like the attached example.
The results/elements will be drawn as big points.
Use the Options-Geometry-Point options...' window to change its size, to
switch between the 'quick' look and the 'nice' look, and change its 'detail' level.
MESH "puntito" dimension 3 Elemtype Point Nnode 1
Coordinates
1 0.0 0.0 0.0
End Coordinates
Elements
1 1
End Elements
MESH "origen-fin" dimension 3 Elemtype Point Nnode 1
Coordinates
2 0.0 0.0 0.0
3 2.0 0.0 0.0
End Coordinates
Elements
2 2
3 3
End Elements
GiD Post Results File 1.0
Result "Displacement" "Wave" 1 Vector OnNodes
Values
1 0.2 0.309 0
2 0 0 0
3 0 0 0
End values
Result "Displacement" "Wave" 2 Vector OnNodes
Values
1 0.4 0.5878 0
2 0 0 0
3 0 0 0
End values
Result "Displacement" "Wave" 3 Vector OnNodes
Values
1 0.6 0.809 0
2 0 0 0
3 0 0 0
End values
Result "Displacement" "Wave" 4 Vector OnNodes
Values
1 0.8 0.9511 0
2 0 0 0
3 0 0 0
End values
Result "Displacement" "Wave" 5 Vector OnNodes
Values
1 1 1 0
2 0 0 0
3 0 0 0
End values
Result "Displacement" "Wave" 6 Vector OnNodes
Values
1 1.2 0.9511 0
2 0 0 0
3 0 0 0
End values
Result "Displacement" "Wave" 7 Vector OnNodes
Values
1 1.4 0.809 0
2 0 0 0
3 0 0 0
End values
Result "Displacement" "Wave" 8 Vector OnNodes
Values
1 1.6 0.5878 0
2 0 0 0
3 0 0 0
End values
Result "Displacement" "Wave" 9 Vector OnNodes
Values
1 1.8 0.309 0
2 0 0 0
3 0 0 0
End values
Result "Displacement" "Wave" 10 Vector OnNodes
Values
1 2 1.225e-16 0
2 0 0 0
3 0 0 0
End values
Coordinates
1 0.0 0.0 0.0
End Coordinates
Elements
1 1
End Elements
Coordinates
2 0.0 0.0 0.0
3 2.0 0.0 0.0
End Coordinates
Elements
2 2
3 3
End Elements
Values
1 0.2 0.309 0
2 0 0 0
3 0 0 0
End values
Values
1 0.4 0.5878 0
2 0 0 0
3 0 0 0
End values
Values
1 0.6 0.809 0
2 0 0 0
3 0 0 0
End values
Values
1 0.8 0.9511 0
2 0 0 0
3 0 0 0
End values
Values
1 1 1 0
2 0 0 0
3 0 0 0
End values
Values
1 1.2 0.9511 0
2 0 0 0
3 0 0 0
End values
Values
1 1.4 0.809 0
2 0 0 0
3 0 0 0
End values
Values
1 1.6 0.5878 0
2 0 0 0
3 0 0 0
End values
Values
1 1.8 0.309 0
2 0 0 0
3 0 0 0
End values
Values
1 2 1.225e-16 0
2 0 0 0
3 0 0 0
End values
Dear Miguel
To transfer results from uniformly grid of FVM without any coupling
scheme, I definitely have to fixed position of points (in sense of uniform
grid in FVM calculations); therefore, it's necessary to create such a
structured grid. I also attach simple example for your infomation i.e. I
need points located at nodes of these hex elements. I tried to generate mesh
by 'point only' but only unstructured mesh is allowed as shown in fig 3.
Thanks in advanced.
Adisorn
Sent: Friday, April 25, 2003 1:48 PM
Subject: Re: [GiDlist] Can I create structured mesh with only points?
elements'
'detail' level.
Coordinates
1 0.0 0.0 0.0
End Coordinates
Elements
1 1
End Elements
Coordinates
2 0.0 0.0 0.0
3 2.0 0.0 0.0
End Coordinates
Elements
2 2
3 3
End Elements
Values
1 0.2 0.309 0
2 0 0 0
3 0 0 0
End values
Values
1 0.4 0.5878 0
2 0 0 0
3 0 0 0
End values
Values
1 0.6 0.809 0
2 0 0 0
3 0 0 0
End values
Values
1 0.8 0.9511 0
2 0 0 0
3 0 0 0
End values
Values
1 1 1 0
2 0 0 0
3 0 0 0
End values
Values
1 1.2 0.9511 0
2 0 0 0
3 0 0 0
End values
Values
1 1.4 0.809 0
2 0 0 0
3 0 0 0
End values
Values
1 1.6 0.5878 0
2 0 0 0
3 0 0 0
End values
Values
1 1.8 0.309 0
2 0 0 0
3 0 0 0
End values
Values
1 2 1.225e-16 0
2 0 0 0
3 0 0 0
End values
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030425/c3ec73ca/attachment.obj
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030425/c3ec73ca/attachment-0001.obj
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030425/c3ec73ca/attachment-0002.obj
Thanks in advanced.
Adisorn
elements'
'detail' level.
Coordinates
1 0.0 0.0 0.0
End Coordinates
Elements
1 1
End Elements
Coordinates
2 0.0 0.0 0.0
3 2.0 0.0 0.0
End Coordinates
Elements
2 2
3 3
End Elements
Values
1 0.2 0.309 0
2 0 0 0
3 0 0 0
End values
Values
1 0.4 0.5878 0
2 0 0 0
3 0 0 0
End values
Values
1 0.6 0.809 0
2 0 0 0
3 0 0 0
End values
Values
1 0.8 0.9511 0
2 0 0 0
3 0 0 0
End values
Values
1 1 1 0
2 0 0 0
3 0 0 0
End values
Values
1 1.2 0.9511 0
2 0 0 0
3 0 0 0
End values
Values
1 1.4 0.809 0
2 0 0 0
3 0 0 0
End values
Values
1 1.6 0.5878 0
2 0 0 0
3 0 0 0
End values
Values
1 1.8 0.309 0
2 0 0 0
3 0 0 0
End values
Values
1 2 1.225e-16 0
2 0 0 0
3 0 0 0
End values
Can you attach an example?
Adisorn Owatsiriwong wrote:
Dear Miguel
Thanks in advanced.
Adisorn
elements'
'detail' level.
Coordinates
1 0.0 0.0 0.0
End Coordinates
Elements
1 1
End Elements
Coordinates
2 0.0 0.0 0.0
3 2.0 0.0 0.0
End Coordinates
Elements
2 2
3 3
End Elements
Values
1 0.2 0.309 0
2 0 0 0
3 0 0 0
End values
Values
1 0.4 0.5878 0
2 0 0 0
3 0 0 0
End values
Values
1 0.6 0.809 0
2 0 0 0
3 0 0 0
End values
Values
1 0.8 0.9511 0
2 0 0 0
3 0 0 0
End values
Values
1 1 1 0
2 0 0 0
3 0 0 0
End values
Values
1 1.2 0.9511 0
2 0 0 0
3 0 0 0
End values
Values
1 1.4 0.809 0
2 0 0 0
3 0 0 0
End values
Values
1 1.6 0.5878 0
2 0 0 0
3 0 0 0
End values
Values
1 1.8 0.309 0
2 0 0 0
3 0 0 0
End values
Values
1 2 1.225e-16 0
2 0 0 0
3 0 0 0
End values
1.jpg Type: JPEG Image (image/jpeg)
Encoding: base64
2.jpg Type: JPEG Image (image/jpeg)
Encoding: base64
3.jpg Type: JPEG Image (image/jpeg)
Encoding: base64
Dear Miguel
Thanks in advanced.
Adisorn
elements'
'detail' level.
Coordinates
1 0.0 0.0 0.0
End Coordinates
Elements
1 1
End Elements
Coordinates
2 0.0 0.0 0.0
3 2.0 0.0 0.0
End Coordinates
Elements
2 2
3 3
End Elements
Values
1 0.2 0.309 0
2 0 0 0
3 0 0 0
End values
Values
1 0.4 0.5878 0
2 0 0 0
3 0 0 0
End values
Values
1 0.6 0.809 0
2 0 0 0
3 0 0 0
End values
Values
1 0.8 0.9511 0
2 0 0 0
3 0 0 0
End values
Values
1 1 1 0
2 0 0 0
3 0 0 0
End values
Values
1 1.2 0.9511 0
2 0 0 0
3 0 0 0
End values
Values
1 1.4 0.809 0
2 0 0 0
3 0 0 0
End values
Values
1 1.6 0.5878 0
2 0 0 0
3 0 0 0
End values
Values
1 1.8 0.309 0
2 0 0 0
3 0 0 0
End values
Values
1 2 1.225e-16 0
2 0 0 0
3 0 0 0
End values
Encoding: base64
Encoding: base64
Encoding: base64
GiD is not speciallized in only nodes generation. Currently only can
generate unstructured and for volumes.
In other hand, generate also the elements (unneeded for your analysis) can
add some postprocess advantages: contour fill, cuts, graphs, etc not
availables with a "onlypoints" mesh.
From: "Adisorn Owatsiriwong" dollarbulldog at hotmail.com
Sent: Friday, April 25, 2003 2:24 PM
Dear Miguel
mesh
Thanks in advanced.
Adisorn
elements'
to
'detail' level.
Coordinates
1 0.0 0.0 0.0
End Coordinates
Elements
1 1
End Elements
Coordinates
2 0.0 0.0 0.0
3 2.0 0.0 0.0
End Coordinates
Elements
2 2
3 3
End Elements
Values
1 0.2 0.309 0
2 0 0 0
3 0 0 0
End values
Values
1 0.4 0.5878 0
2 0 0 0
3 0 0 0
End values
Values
1 0.6 0.809 0
2 0 0 0
3 0 0 0
End values
Values
1 0.8 0.9511 0
2 0 0 0
3 0 0 0
End values
Values
1 1 1 0
2 0 0 0
3 0 0 0
End values
Values
1 1.2 0.9511 0
2 0 0 0
3 0 0 0
End values
Values
1 1.4 0.809 0
2 0 0 0
3 0 0 0
End values
Values
1 1.6 0.5878 0
2 0 0 0
3 0 0 0
End values
Values
1 1.8 0.309 0
2 0 0 0
3 0 0 0
End values
Values
1 2 1.225e-16 0
2 0 0 0
3 0 0 0
End values
Dear Miguel
mesh
Thanks in advanced.
Adisorn
elements'
to
'detail' level.
Coordinates
1 0.0 0.0 0.0
End Coordinates
Elements
1 1
End Elements
Coordinates
2 0.0 0.0 0.0
3 2.0 0.0 0.0
End Coordinates
Elements
2 2
3 3
End Elements
Values
1 0.2 0.309 0
2 0 0 0
3 0 0 0
End values
Values
1 0.4 0.5878 0
2 0 0 0
3 0 0 0
End values
Values
1 0.6 0.809 0
2 0 0 0
3 0 0 0
End values
Values
1 0.8 0.9511 0
2 0 0 0
3 0 0 0
End values
Values
1 1 1 0
2 0 0 0
3 0 0 0
End values
Values
1 1.2 0.9511 0
2 0 0 0
3 0 0 0
End values
Values
1 1.4 0.809 0
2 0 0 0
3 0 0 0
End values
Values
1 1.6 0.5878 0
2 0 0 0
3 0 0 0
End values
Values
1 1.8 0.309 0
2 0 0 0
3 0 0 0
End values
Values
1 2 1.225e-16 0
2 0 0 0
3 0 0 0
End values
If the nodes follow a given ordering and there is only one block of
elements, the code that
you need to program to create the elements is really trivial. I am sure
that you can program
it in less that 20 lines of code (of TCL of course). Ask for more help
if you are not able to do it.
http://www.compassis.com http://www.compassis.com/
ramsan at compassis.com
[mailto:gidlist-admin at gatxan.cimne.upc.es] En nombre de Adisorn
Owatsiriwong
Enviado el: viernes, 25 de abril de 2003 12:49
Para: GiD
Asunto: [GiDlist] Can I create structured mesh with only points?
Dear GiD Team,
unstructured mesh.
Bests,
Adisorn
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030425/77962cb9/attachment.htm
Owatsiriwong
Para: GiD
Dear GiD Team,
unstructured mesh.
Bests,
Adisorn
MensajeDear GiD Teams,
Thank you for all useful answer, Thank also for Dr.Ribo. I am very new to tcl and it's so important to have all of your guidances. Anyway, it means people need to use hex elements in transferring results from Finite Volume (in case they will not modify GiD), can anybody provide me a case study for this.
Adisorn
Sent: Friday, April 25, 2003 5:04 PM
Subject: RE: [GiDlist] Can I create structured mesh with only points?
If the nodes follow a given ordering and there is only one block of elements, the code that
you need to program to create the elements is really trivial. I am sure that you can program
it in less that 20 lines of code (of TCL of course). Ask for more help if you are not able to do it.
De: gidlist-admin at gatxan.cimne.upc.es [mailto:gidlist-admin at gatxan.cimne.upc.es] En nombre de Adisorn Owatsiriwong
Para: GiD
Dear GiD Team,
Bests,
Adisorn
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030425/56bd820c/attachment.htm
Adisorn
Para: GiD
Dear GiD Team,
Bests,
Adisorn
[GiDlist] Draw Local Axes in Post processing
Hi GiD Team
Could you Please show how to specify the local axes
in the post processing. I've tried as instructed in
on-line document but it's not working out.
OK let's say local axes for each element at a
centroid.
For example if I have values for local axes as:
x'=[1,0,0]
y'=[0,1,0]
z'=[0,0,1]
How to write the post for these vectors???
Many thanks
Do you Yahoo!?
The New Yahoo! Search - Faster. Easier. Bingo.
http://search.yahoo.com
centroid.
x'=[1,0,0]
y'=[0,1,0]
z'=[0,0,1]
Many thanks
Do you Yahoo!?
