[GiDlist] mirror images
Pablo
Post by Pablo »
Hi again enrique,
I´m trying to work as automatically as i can, so im trying to edit thi mehs
file only pasting it in my mesh file data. But when the postprocessor is
reading gives me the followin message:
"Point number out of range?: 500007 not in [ 1, 2] Reading Mesh." and i
don´t know wy. Maybe you can tell me what does it mean...
Pablo Fariñas
Sent: Friday, March 07, 2003 9:13 PM
Subject: Re: [GiDlist] mirror images
It can be a binary results file: open with GiD postprocess, and save it in
ascii format before to edit
(Files-Export-Post Information-Ascii files)
Sent: Thursday, March 07, 2002 8:22 PM
Hi again,
I got another problem with editing my *.flavia.res (the file of results
of
numerical solutions). I can´t edit it. I am trying to edit it with the
notebook but it seems like the file was encripted... Don´t know wy is
happening this, maybe you have an answer...
In order to dont work with editing the files of results, (in the version
7.x). do you think that could be more easy work only with postprocess of
an
older version wich can merge both solutions??? I have tried to do it but
i
did not obtain any image at all.
Bye, Pablo Fariñas.
Sent: Friday, March 07, 2003 11:00 AM
hi,
it seems that the year of your computer is not the actual one.
as i told on previous messages, in gid 7.x is a bug when merging
files:
it does not mege the results as expected. it only maintains the ones
of the last mesh. Will be solved for the next version.
What you can do to overcome this problem is:
1. put all the meshes inside the same .msh file:
for instance:
cat mesh1.msh mesh2.msh mesh3.msh all_meshes.msh
2. put all the results inside the same the same .res file and the
same results under the same result header. This requires a little
bit of editing . . . sorry
Pablo wrote:
Hello again,
As you tell me I have taken several items into account. First, the
results
should be at the same time step, in spite of this i wrote at the
*.flavia.res the number of 103.5 as the step. As you can see, the
names
of
results displayed are the same than your tdyn cálculus module. (I
think
that
in this way it should not be a problem). On the other side, about
the
numbering of my attached mesh nodes, as you can see at the attached
file
*.flavia.mesh, the first number of the first node is 500001 and my
numerical
problem has about 75000 nodes (i think that there should not be a
problem in
this way too).
Aniway my problem persist... i don´t know if you can think in
another
kind
of solution...
See you,
Pablo Fariñas.
From: "Miguel A. de Riera Pasenau" gid at gatxan.cimne.upc.es
Sent: Friday, March 07, 2003 9:07 AM
there are only one set of files/results:
C1 - RANSOL analysis, 103.5 as step
results: 'EDDY ENERGY' and 'VELOCITY'
'merge ascii' - this adds another mesh and/or results to the
current
one.
does not renumber the nodes so if in the second
mesh
you are using as node numbers 1..100, then the
nodes
1..100
of the mesh inside GiD will be overwritten.
Looking at the file it seems that you already have
taken
this
into account.
to view results the results the result's name, analysis name and
step
value
should be the same on both models, so that just doing 'View
results-C.Fill-Eddy.../Vel...
you'll get the results of both meshes.
Pablo wrote:
Hello everyone,
I´m working comparing numerical and experimental results. What I
want is
be able to see both images (numerical and exper) in a
mirror view. In this way I have arranged the files *.flavia.mesh
and
*.flavia.res (Are attached to this mail and are the exper.
results) and I have tried to see both images at the same time by
the
postprocess menu "merge ascii" to the numerical file results.
I don´t know why this procedure does not work properly...
Will wait for your suggestions...
Bye
Pablo Fariñas
Dpt. Shipbuilding Engineering of A Coruña University
C1.flavia.msh Type: unspecified type
(application/octet-stream)
Encoding: 7bit
C1.flavia.res Type: unspecified type
Encoding: 7bit
Miguel A. de Riera Pasenau miguel at cimne.upc.es
Post by Miguel A. de Riera Pasenau »
something is worng with the mesh.
can you post it so we can take a look at it?
Pablo wrote:
Hi again enrique,
Pablo Fariñas
Hi again,
of
an
i
Bye, Pablo Fariñas.
hi,
files:
for instance:
Pablo wrote:
Hello again,
results
names
of
think
that
the
file
numerical
problem in
this way too).
another
kind
of solution...
See you,
Pablo Fariñas.
current
one.
mesh
nodes
1..100
taken
this
into account.
step
value
Pablo wrote:
Hello everyone,
want is
and
the
Bye
Pablo Fariñas
Encoding: 7bit
Encoding: 7bit
Pablo
Post by Pablo »
sending attached file...
Sent: Tuesday, March 11, 2003 9:01 AM
Pablo wrote:
Hi again enrique,
mehs
Pablo Fariñas
it in
Hi again,
results
of
the
is
version
postprocess of
an
but
i
Bye, Pablo Fariñas.
hi,
files:
ones
for instance:
little
Pablo wrote:
Hello again,
the
results
the
names
of
(I
think
that
about
the
attached
file
my
numerical
a
problem in
this way too).
another
kind
of solution...
See you,
Pablo Fariñas.
current
one.
second
mesh
nodes
1..100
have
taken
this
into account.
and
step
value
Pablo wrote:
Hello everyone,
What I
want is
*.flavia.mesh
and
time by
the
Bye
Pablo Fariñas
Encoding: 7bit
Encoding: 7bit
An embedded and charset-unspecified text was scrubbed...
Url: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030311/a60b0e03/attachment.txt
Pablo Perez del Castillo
[GiDlist] postprocess
Post by Pablo Perez del Castillo »
Hello;
I have two questions:
1) i have a aerodynamic results over bodies, and i calculate center of effort,
so i would like to postprocess the point of center of effort with vector force.
I thought in add a new node (or element node), is there a best solution??
2) Now i have over 10 iterations for every load condition and postprocess ok,
but if i wish calculate 6 or more load conditions in every file, how can i must
to ready the postprocess?
Advanced thanks
