[GiDlist] mirror images
Pablo
Post by Pablo »
Hello everyone,
I´m working comparing numerical and experimental results. What I want is be able to see both images (numerical and exper) in a mirror view. In this way I have arranged the files *.flavia.mesh and *.flavia.res (Are attached to this mail and are the exper. results) and I have tried to see both images at the same time by the postprocess menu "merge ascii" to the numerical file results.
I don´t know why this procedure does not work properly...
Will wait for your suggestions...
Bye
Pablo Fariñas
Dpt. Shipbuilding Engineering of A Coruña University
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030306/ab10d367/attachment.htm
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030306/ab10d367/attachment.obj
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030306/ab10d367/attachment-0001.obj
Pablo
Post by Pablo »
Hello enrique, i dont really know what you mean. Are you sure you have answred my question??
You send me an answer for a question about "conditions" The answer was for a mail with a subjet "loop over condition". Thanks aniway. But i will wait again... (my subjet was "mirror images"...).
Pablo Fariñas.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030306/8df3e801/attachment.htm
Miguel A. de Riera Pasenau
Post by Miguel A. de Riera Pasenau »
there are only one set of files/results:
C1 - RANSOL analysis, 103.5 as step
results: 'EDDY ENERGY' and 'VELOCITY'
'merge ascii' - this adds another mesh and/or results to the current one.
does not renumber the nodes so if in the second mesh
you are using as node numbers 1..100, then the nodes 1..100
of the mesh inside GiD will be overwritten.
Looking at the file it seems that you already have taken this
into account.
to view results the results the result's name, analysis name and step value
should be the same on both models, so that just doing 'View results-C.Fill-Eddy.../Vel...
you'll get the results of both meshes.
Pablo wrote:
Hello everyone,
Bye
Pablo Fariñas
C1.flavia.msh Type: unspecified type (application/octet-stream)
Encoding: 7bit
C1.flavia.res Type: unspecified type (application/octet-stream)
Encoding: 7bit
Preparing an example about this i noticed that there is a bug, in version 7.x
in the 'merge' option: it doesn't not merge the results as it should be.
Pablo Fariñas.
But you can write all the meshes inside the same .msh file,
and the results inside the same .res file.
into account.
Pablo wrote:
Hello everyone,
Bye
Pablo Fariñas
Encoding: 7bit
Encoding: 7bit
Pablo
Post by Pablo »
Hello again,
As you tell me I have taken several items into account. First, the results
should be at the same time step, in spite of this i wrote at the
*.flavia.res the number of 103.5 as the step. As you can see, the names of
results displayed are the same than your tdyn cálculus module. (I think that
in this way it should not be a problem). On the other side, about the
numbering of my attached mesh nodes, as you can see at the attached file
*.flavia.mesh, the first number of the first node is 500001 and my numerical
problem has about 75000 nodes (i think that there should not be a problem in
this way too).
Aniway my problem persist... i don´t know if you can think in another kind
of solution...
See you,
Pablo Fariñas.
From: "Miguel A. de Riera Pasenau" gid at gatxan.cimne.upc.es
Sent: Friday, March 07, 2003 9:07 AM
Subject: Re: [GiDlist] mirror images
1..100
this
into account.
value
Pablo wrote:
Hello everyone,
Bye
Pablo Fariñas
Encoding: 7bit
Encoding: 7bit
hi,
it seems that the year of your computer is not the actual one.
as i told on previous messages, in gid 7.x is a bug when merging files:
it does not mege the results as expected. it only maintains the ones
of the last mesh. Will be solved for the next version.
What you can do to overcome this problem is:
1. put all the meshes inside the same .msh file:
for instance:
cat mesh1.msh mesh2.msh mesh3.msh all_meshes.msh
2. put all the results inside the same the same .res file and the
same results under the same result header. This requires a little
bit of editing . . . sorry
Pablo wrote:
Hello again,
this way too).
of solution...
See you,
Pablo Fariñas.
1..100
this
into account.
value
Pablo wrote:
Hello everyone,
Bye
Pablo Fariñas
Encoding: 7bit
Encoding: 7bit
Pablo
Post by Pablo »
Hi again,
I got another problem with editing my *.flavia.res (the file of results of
numerical solutions). I can´t edit it. I am trying to edit it with the
notebook but it seems like the file was encripted... Don´t know wy is
happening this, maybe you have an answer...
In order to dont work with editing the files of results, (in the version
7.x). do you think that could be more easy work only with postprocess of an
older version wich can merge both solutions??? I have tried to do it but i
did not obtain any image at all.
Bye, Pablo Fariñas.
Sent: Friday, March 07, 2003 11:00 AM
hi,
for instance:
Pablo wrote:
Hello again,
results
of
that
numerical
problem in
this way too).
kind
of solution...
See you,
Pablo Fariñas.
one.
1..100
taken
this
into account.
value
Pablo wrote:
Hello everyone,
want is
Bye
Pablo Fariñas
Encoding: 7bit
Encoding: 7bit
It can be a binary results file: open with GiD postprocess, and save it in
ascii format before to edit
(Files-Export-Post Information-Ascii files)
Sent: Thursday, March 07, 2002 8:22 PM
Hi again,
an
Bye, Pablo Fariñas.
hi,
for instance:
Pablo wrote:
Hello again,
results
names
of
think
that
file
numerical
problem in
this way too).
kind
of solution...
See you,
Pablo Fariñas.
one.
1..100
taken
this
into account.
step
value
Pablo wrote:
Hello everyone,
want is
and
the
Bye
Pablo Fariñas
Encoding: 7bit
Encoding: 7bit
Pablo
Post by Pablo »
Problem solved, thanks,
Pablo Fariñas.
Sent: Friday, March 07, 2003 9:13 PM
Hi again,
of
an
i
Bye, Pablo Fariñas.
hi,
files:
for instance:
Pablo wrote:
Hello again,
results
names
of
think
that
the
file
numerical
problem in
this way too).
another
kind
of solution...
See you,
Pablo Fariñas.
current
one.
mesh
nodes
1..100
taken
this
into account.
step
value
Pablo wrote:
Hello everyone,
want is
and
the
Bye
Pablo Fariñas
Encoding: 7bit
Encoding: 7bit
