[GiDlist] Some small problems
Andrea Calaon
Post by Andrea Calaon »
Hi everyone,
before Christmas I sent this mail, but it probably
went missed in the holiday rush. I send it again
hoping not to disturb.
Have a nice day!
Hi everyone,
I have two minor problems I would like to get rid of:
In EndGIDProject I use this code:
if { $NewProblemType == "Yes" } {
after 1000 RestoreColors
but the RestoreColors doesn't work properly, and
sometimes I need to give the same open command
twice for opening a .gid "directory-file". Is there
any other more reliable way to restore the original
colours without using the "after command"?
(changing the time delay doesn't eliminate the
problem).
WhenI open a file that belongs to my ProblemType
having the ProblemType already loaded I always
receive this message:
Project 'utilities' doesn't exist or it is a problem
type. Leaving.
Apart from the message itself, this hasn't caused
any more troubles and I normally just close the
dialog.
I have no Idea where this could come from, and I
tried to modify something but nothing has worked
Thanks in advance for any suggestions
Best Regards
Recently I have also experienced some difficulties
with the post-processing command "Do cuts - Divide
by selection": I loose the selection possibility once I
pan, rotate or zoom the model view.
Kind Regards
Andrea Calaon
Ashurst Lodge, Ashurst
Southampton, Hampshire
SO40 7AA, UK
Fax office: +44 23 80 292 853
Mobile: +44 7766 488 225
E-mail: andrea at beasy.com
Hello Andrea.
Send me a zip file with your current problemtype (the analysis code is not
necessary), the make some tests.
Note: send directly to escolano at cimne.upc.es
Sent: Thursday, January 15, 2004 12:49 PM
Subject: [GiDlist] Some small problems
Hi everyone,
Have a nice day!
Hi everyone,
problem).
type. Leaving.
dialog.
Best Regards
Kind Regards
Andrea Calaon
SO40 7AA, UK
