RV: [GiDlist] post processing graphs
Post by miguel »
De: Miguel A. Pasenau de Riera [mailto:miguel at cimne.upc.edu]
Enviado el: martes, 07 de junio de 2005 17:14
Para: 'gidlist at gatxan.cimne.upc.edu'
Asunto: RE: [GiDlist] post processing graphs
At the momnent it is not possible to make a graph of gaussian results nor
represent gaussian results on a cut. We are working on that and will be
available on next versions.
De: gidlist-admin at gatxan.cimne.upc.edu
[mailto:gidlist-admin at gatxan.cimne.upc.edu] En nombre de Mark Smith Enviado el:
martes, 07 de junio de 2005 11:37
Para: gidlist at gatxan.cimne.upc.edu
Asunto: [GiDlist] post processing graphs
Win2000
GiD7.5.8b
I have a set of results on gauss points on constant triangular flat surface
elements. How do I define a contour/line so that I can display a graph of
interpolated values along the line?
With border graph I am only able to display graphs of data which is evaluated
at the nodes, why can't I display those results evaluated at gauss points?
This has not been possible with all versions of GiD that I've tried, it seems
such a basic necessity and in most other post processors you define a contour &
are able to display variation along it.
mark
The information contained in this e-mail message (and any attachment
transmitted herewith) is privileged and confidential and is intended for the
exclusive use of the addressee(s). If you are not an addressee, any disclosure,
reproduction, distribution or other dissemination or use of this communication
is strictly prohibited. If you have received this communication in error,
please contact us immediately so that we can correct the error.
