Hello.
I'm trying to assign unstructured sizes with a background mesh and to
generate a new mesh but GiD crashes even with simple geometries.
I attach a file (cube.zip) with an example.
What am I doing wrong? (I'm using GiD 7.2.)
Thank you.
Marc.
Type: application/zip
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050603/89489a1a/attachment.zip
[GiDlist] Mesh generation with a background mesh crashes
Your files are Ok.
It is a corrected bug of the 7.2 version. Download a new beta version, like
the 7.5.8b
http://www.gidhome.com/download/do07.subst
Note: Can use the program md5.exe in order to check the integrity of the
downloaded files.
for example, for the Windows version, open a command window, and write
md5.exe GiD7.5.8b-win.exe
If you obtain a code different of : 8ed8b9a6f1fba31e11e5c3de47d4e47b
then the downloaded file is corrupted, and must be downloaded again.
Sent: Friday, June 03, 2005 10:27 AM
Subject: [GiDlist] Mesh generation with a background mesh crashes
Hello.
Thank you.
Marc.
the 7.5.8b
downloaded files.
Hello.
Thank you.
Marc.
